01-11-2012, 05:40 PM | #1 |
| Swapped out ESCs
I just swapped out a Mamba Max for a HH BR-XL on a HH 30T motor. The motor is not chiming. I hooked up a silver can and it works just fine. Hooked up the Mamba Max back up...no chime. WTH.....nothing else has changed. I see lights on both ESCs and it's responding to my throttle inputs (lights changing on ESC). Any ideas?
01-11-2012, 06:06 PM | #2 |
RCC Addict Join Date: Jul 2011 Location: Orlando
| Re: Swapped out ESCs
I would guess you may have to calibrate the New HH BRXL to your reciever. Then try it and see what happens.
01-11-2012, 06:14 PM | #3 |
| Re: Swapped out ESCs I have calibrated the ESC to the Tx. ESC not at fault b/c it works fine with another motor. Something to do with the motor. All solder connections are good.
01-11-2012, 06:15 PM | #4 |
Pebble Pounder Join Date: Mar 2010 Location: PHX
I'm having the same issue. I hooked it all up. ran for a few minutes until I snapped may stock drive shaft. Got some MIPs and now I get what OP describes. tried to re-calibrate and still nothing. Hooked up the castle link, reset to default, still nothing. Any more info would be helpful to me as well.
01-11-2012, 06:30 PM | #5 |
Nobody Join Date: Sep 2008 Location: Maine
Does the motor turn if you put power directly to it?
01-11-2012, 06:34 PM | #6 |
I just hooked up a battery (AA) to the motor and I have nothing. Motor isn't locked up...still spins freely. Update: It working just fine now. Forgot that I did mess with one of the brushes...might not have been fully seated. |
01-11-2012, 06:38 PM | #7 |
Hooked to any other esc, my motors work.
01-11-2012, 06:46 PM | #8 |
| Re: Swapped out ESC's
Wow, busy night.... -If a motor does not work in a rig, BUT does work with a direct connect to a battery, the issue is the ESC. -If a motor does not work in a rig, AND it does not work with a direct connect to a battery, the issue is the motor. ESC can be ESC to RX calibration, ESC settings (like the ESC LVC), bad ESC, bad battery Motor can be a dead motor, or a loose brush connection, hung brush (provided the motor spins freely by hand). |
01-12-2012, 01:13 AM | #9 |
Problems solved. Dead bands were set way low. Working like a champion.
Swapped out ESCs - Similar Threads | ||||
Swapped the chassis on my RF!! :) | Madpete98 | Kyosho Crawlers | 9 | 03-10-2009 09:08 AM |
Body swapped | rckjeep | 2.2 Scale Rigs | 15 | 10-10-2007 10:16 AM |
WK swapped ends, it's easy | MikeSSS | HPI Wheely King | 4 | 05-10-2007 10:34 PM |
All These ESCs !! | pc6uru | Electronics | 6 | 05-05-2007 06:18 PM |
Swapped in real electronics... | 350jeepcj5 | General Crawlers | 9 | 04-22-2006 11:41 PM |
