Thread: esc question?
Old 01-21-2012, 12:04 AM   #1
Default esc question?
this probably a dumb question.....if an esc has a 35 turn motor limit would it work for a 100 turn motor??
rc2008 is offline   Reply With Quote
Old 01-21-2012, 12:13 AM   #2
Default Re: esc question?
Yes, it will work.
Just curious, what are you running a 100T motor in?
Greatscott is offline   Reply With Quote
Old 01-21-2012, 07:23 AM   #3
just to let you know the motor limit on the esc means it cant't handle anything under the limit it says. anything above is fine
Steve p is offline   Reply With Quote
Old 01-21-2012, 08:21 AM   #4
im running it in a redcat rockslide 1/8 scale crawler.
Thanks guys for the help. i just wanted to make sure before i spend over $100 for a pair of esc's and then they not work for it
Old 01-23-2012, 11:41 AM   #5
With motors, the lower turn windings, the more amps the motor will draw to produce the same amount of torque. So a 35T motor will draw way more amps (and put more stress on your electronics) than a 55T or even a 100T would in the same bind or climbing the same obstacle.
This example assumes that you have the same number of poles in the motors.
hibbs is offline   Reply With Quote
esc question? - Similar Threads
ESC Question tolowbro Electronics 0 02-22-2011 02:08 PM
ESC question martinez34 Electronics 8 02-21-2011 02:46 PM
ESC question sweetride4me Electronics 5 03-02-2009 07:42 PM
esc question snowball50 Electronics 7 01-29-2007 03:57 PM
