06-05-2015, 12:39 AM | #1 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| bec for the ascender.
I know I need it, but I forgot to order a damn Y-harness, so can I just do it like this photo, cause that's almost how the stock Rx is laid out, well there's a bind port, steering port, throttle port, aux1, and aux 2. I figured I'd just use either aux port and disconnect the positive from the ESC like photo. You see I'd've just ordered the heyok no brainer, and been done with it, but I have the CC on hand, and I wanna play today not in 5 days. Last edited by Alexander_0_1; 06-05-2015 at 12:55 AM. |
06-05-2015, 12:56 AM | #2 |
Quarry Creeper Join Date: Nov 2013 Location: lethbridge,alberta, its mighty windy here!!
| Re: bec for the ascender.
just plug the castle bec into the batt and/or bind port, that way you wont loose any of your aux channels by plugging it in their. dont forget to pull the esc red wire and maybe the signal wire from the bec if going into bind port, the castle bec's look for a specific signal on the pin so may or may not be tricked into going into castle link mode if it recieves a signal on that pin from rx, something they had issues with on earlier versions and spektrums i read but supposedley less so now. tony |
06-05-2015, 01:00 AM | #3 |
Thanks, much appreciated, I'll do just that.
bec for the ascender. - Similar Threads | ||||
BEC | Castle Creations CC Bec 10A 6S Switching Regulator | le varan | Axial Yeti | 8 | 06-02-2015 12:08 PM |
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
