02-08-2012, 07:28 PM | #1 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo?
I just purchased a new Axial AE-2 esc. On the sticker on the esc itself, it says 2S LiPo. However, I've read many members on here that say they've ran 3S LiPo with a BEC. So, how do I wire/solder a Castle 10A BEC so that I can run 3S LiPo batteries on the AE-2 esc? Diagrams would be helpful. TIA.
02-08-2012, 07:31 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
| Re: how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo?
easy...cut off old esc batt plug...solder bec power wires to new batt plug....and use castle link to program ae-2 for 3s.....
02-08-2012, 07:38 PM | #3 |
I'm kind of a visual learner, so a diagram would be helpful. Thanks.
02-08-2012, 07:42 PM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: Gaffney
| Re: how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo? Last edited by Goatsniper; 02-08-2012 at 07:45 PM. |
02-08-2012, 07:45 PM | #5 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
Make sure you unhook the red wire on the 3 wire plug from the ESC to the RX.. The RX will get its power from the BEC now. What I do is get a servo extension wire and cut it in half.. Then hook the female end to the battery wires or plug of the ESC. Then Solder the other half to the 2 wires coming off the BEC.. You only need the red and black or the orange and brown depending on the brand name of the servo extension.. The yellow wire is not used for my power plug mod.. This mod then allows you to plug your BEC into the ESC's battery plug wires, and has the ability easily disconnect if you want to use the ESC or BEC on another project. Sent from my highly abused iPhone using Tapatalk |
02-08-2012, 07:45 PM | #6 | |
| Re: how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo? Quote: USS.....the CC diagram does the basics, how to go through the RX vs direct to the servo needs a bit more looking..... I prefer direct BEC to servo wiring. | |
02-08-2012, 07:50 PM | #7 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Re: how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo? |
02-08-2012, 08:09 PM | #8 |
Thanks for the quick responses guys. So, basically, the higher voltage from the 3S LiPo battery is to run through the 10A Castle BEC (set at, let's say 6.0V) to power directly to the servo, instead of the AE-2 internal BEC, powering the servo, right? Then, the CC 10A BEC is necessary to run higher voltages to the servo, but, what about the AE-2 esc? Do I just re-program it using a castle Link, and change it to 3S? From what I'm understanding, then, is that, the BEC is there, for reasons pertaining to the servo, and has really nothing to do with the esc itself?
02-08-2012, 10:26 PM | #9 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
| Re: how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo? The AE-2 is set from the factory for "Auto", meaning it will automatically detect the type of battery (eg. 2S, 3S). Just solder up the BEC per previous instructions and plug in your battery of choice. You'll hear three beeps on start-up indicating a 3S battery.
02-09-2012, 02:18 AM | #10 | |
Pebble Pounder Join Date: Feb 2011 Location: Northwich, England
Pete. | |
how do I wire/solder a Castle 10A BEC to an AE-2 esc, to run 3S LiPo? - Similar Threads | ||||
how do I wire/solder 2 CC 10A BECs for 4WS (2 servos)? | ussprinceton2004 | Axial Wraith | 23 | 01-29-2012 08:24 PM |
@@@ Castle Creations 10A BEC Giveaway! @@@ | y2kgtp | General Crawlers | 436 | 02-13-2011 07:54 AM |
castle bec? what does the signal wire do? | driftin90 | Electronics | 2 | 07-19-2009 05:16 PM |
quark 33 and castle BEC. remove esc power wire? | dieselfuel | Electronics | 2 | 03-21-2008 12:12 AM |
