02-14-2012, 06:26 AM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: USA
| mtor will only go 1 way....help please...
ok guys...ill start at the begining...my buddy had the losi insane motor in his MRC all the other electronics are stock....he ran it for maybe a total of 20-30 minutes and decided he was gonna take it off and do a water break in to it...so we took the electronics off and started the break in and in about 5 minutes we noticed the esc was getting pretty warm so we stopped....a huge amount of crude had been flushed from the motor so at that point we also decided to stop the break in and go with what we had....we let the esc cool down and the motor dry a few minutes and before we reinstalled everything we decided to test and make sure everything was ok and this is where the problem presented itself... as soon as we tried it we noticed the motor would go fine in revers but no forward...so we reversed the channel and it had forward and no reverse...at this point i was thinking it was the radio so i hooked up my rx (which i had used the night before and it worked perfectly) and got the same results...so not being sure what the problem was i decided to start switching components to see if i could figure out the problem....we had two radios, two esc's, and three motors...no matter what combination we hooked this stuff up we got the same results...we could only go in one direction....even using all my electronics that worked perfectly when we removed them a few weeks earlier we still had the same issue...so im starting to think i am doing something wrong....i don't see how all of this stuff could screw up in the same way at the same time randomly like that...im really confused and need some opinions....at this point i don't even know what to do to diagnose the problem....help me out guys... Last edited by pugs2300; 02-14-2012 at 10:35 AM. |
02-15-2012, 06:19 AM | #2 |
| Re: mtor will only go 1 way....help please...
no one has any idea...well i don't either so...
02-15-2012, 06:31 AM | #3 |
Nobody Join Date: Sep 2008 Location: Maine
In switching all the components around, did you calibrate the esc properly to the tx/rx? 99% chance you toasted that motor sticking it in water. That probably wasnt crud flushing from the motor, it was your brushes wearing away to nothing. |
02-15-2012, 07:40 AM | #4 |
well that is the way i was told to break in a brushed motor by everything i have ever read.... and besides that we had two other motors that hadn't been broken in that way... i am just totally lost as to what to do next or how to figure out what the problem is...we have taken all these components out many times to move them around on our rigs and nothing has ever lot its program before... |
02-15-2012, 08:05 AM | #5 | |||||
When things arent going right with your electronics, always start back at the basics. Randomly swapping things around can just make it worse. Check your epa settings, zero the throttle trim, remove the BEC if you have it, make sure the Tx batteries are good, use a good charged battery on the esc, make sure the esc to motor connections are soldered properly, and recalibrate the esc to the Tx. Here's a few recent posts in this forum from very credible people that I found real quick about water break in. Quote:
02-15-2012, 08:06 AM | #6 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Uh, you used the ESC to break in the motor in water? Once you ran the motor, there is little point going back and trying to break it in, especially in water no less... The water doesn't just dry on its own, it needs to be blown and cleaned out... My guess, you toasted the ESC....they are not meant to be used for water break in.....and more than likely the motor is toast also. Later EddieO |
02-15-2012, 08:19 AM | #7 |
ok all of this would make perfect sense if it wasnt for the fact that i had a motor and esc that never seen water doing the exact same thing... as far as the credibility of a water break in i was just goin on what i read...and as far as using the esc to break it in i was following the instruction of a ultimate rc breakin video... still new to all this...especially the electric stuff...i started with nitros... since it was doin it with three different motors...(only 1 of which was water broke in)....and two diff esc's....i dont know what would need to be replaced...my guess is the esc...we did put the other esc on the water broke in motor so i guess the motor could have fried that esc as well????... if thats the case....what is a good low cost esc to replace the one we may have fried...?? Last edited by pugs2300; 02-15-2012 at 08:22 AM. |
02-15-2012, 08:33 AM | #8 |
If you removed the motor that was broken in in water before you hooked up the OTHER ESC and motor and had the same issue then it's most likely your Tx calibration with the ESC. If you swapped the OTHER ESC onto the motor that was broken in in water then I'd say the motor screwed something up in the ESC's. |
02-15-2012, 08:51 AM | #9 |
ok im not 100% sure what order we did the swapping is but i think we tried the other esc on the watered motor first...so ill go with that...
02-15-2012, 09:33 AM | #10 |
The Ultimate RC guys are about as good with Motors as I am with Pole Dancing....after watching some of their other videos, I have come to the determination you are better off taking driving lessons from Stevie Wonder. If you toasted the motor during water break in, it could of shorted........and sent some nasty feedback to the ESC. If it has continued to short, and you hooked it up to another ESC....then it could short it out as well. Shorted motors can be the same as twisting the two motor leads together and then pulling the trigger.... I do suspect there maybe calibration issues though, as it almost sounds like the radio doesn't know where forward is, especially since you now say the problem has repeated on other units not subject to water break in, though its possible the shorted out ESC/Motor caused the reciever issue. Later EddieO |
02-15-2012, 10:23 AM | #11 |
yea i had two esc's two radios (tx and rx)and three motors....same issue with all of them....no matter how we hooked them up.. one other piece of info that comes to mind....when we tried to apply throttle in the direction it wouldn't go the lights on the esc acted just as they would if everything was working fine...it turned green with throttle input and red when at WOT....this is what both of the esc have always done since they were new..so i assume thats what they should do....so i know the esc is gettin the go input but it just wont go...lol... |
02-15-2012, 10:48 AM | #12 |
Plug a servo into the throttle channel and see if it sweeps back and forth with trigger input. Boom, if it works fine then you know the signal is good and can eliminate a faulty radio from the list of possible causes. Second step is to calibrate the ESC and make sure it "knows" what signal means what. If none of that helps then I am confident that you need to buy a motor and ESC. There are a lot of options for the MRC, I suggest you check out the MRC section on here and do some reading and check out what others are using. |
02-15-2012, 11:13 AM | #13 |
thanks guys...i really appreciate all the help...i didn't think about trying the servo in the throttle channel...
mtor will only go 1 way....help please... - Similar Threads | ||||
New or used? I'm confused | desertmaxx | General Crawlers | 25 | 11-03-2010 10:37 PM |
confused.. | mcreil41 | Paint and Body | 2 | 11-23-2009 06:16 PM |
little confused.. | mcreil41 | Electronics | 7 | 11-20-2009 01:03 PM |
I'm so confused!!!! | blackcatnastang | Newbie General | 22 | 03-19-2008 07:20 PM |
I'm So Confused!!! | demonoid369 | Newbie General | 11 | 01-28-2008 06:16 PM |
