03-08-2012, 04:30 PM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: Ontario,Canada
| Hobby king 60amp esc
I just got this 60 amp esc from hobby king ,I done the set up as per the instructions put it on a new brushless motor, it worked for about four laps around the living room then quit. The lights on the esc change with forward and revese. The other thing that is not working is the beeps when it's first powered up or during set up. Is it junk? It doesn't look or smell burnt. Any ideas? |
03-08-2012, 04:44 PM | #2 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: Hobby king 60amp esc
The last time I had an experience like that. I had an esc that was programmed for lipo cutoff and I was using a nicad, so it shut down after a very short run.
03-08-2012, 04:45 PM | #3 | |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
| Re: Hobby king 60amp esc Quote:
What ESC did you get ? Got a link... I'm using one of there Turnigy TrackStar 60amp ESC HobbyKing R/C Hobby Store : Turnigy TrackStar 1/10th Scale 60A Car ESC ( programed with the card) with a 6.5t brushless motor, never had any trouble with it... Did it over heat ? Sean | |
03-08-2012, 04:51 PM | #4 |
| Re: Hobby king 60amp esc HobbyKing R/C Hobby Store : HobbyKing Brushless Car ESC 60A w/ Reverse theres the link. It wasn't over heated it only run for 2 minuets max. I had a 13.5 turn sensored motor on it with a 18T pinion |
03-08-2012, 04:54 PM | #5 |
I forgot to mention that I also have the programming card and when I plug it in to the esc it doesn't turn the card on either. The wire is not broke.
03-08-2012, 05:01 PM | #6 | |
Did you plug into the card first and then plug battery in... Can you test the ESC with another motor... I'm sure the beeping sound comes from the motor ,not the ESC.. | |
03-08-2012, 05:07 PM | #7 | |
I can try another motor, does it have to be sensorless or can it be sensored? (kinda new to this) | |
03-08-2012, 05:12 PM | #8 |
| Re: Hobby king 60amp esc |
03-08-2012, 05:40 PM | #9 |
Rock Stacker Join Date: Feb 2012 Location: Enfield CT.
I got this one from hobby king HobbyKing R/C Hobby Store : Turnigy TrackStar 120A 1/10th Scale Sensored Brushless Car ESC It worked great up and down the street with tons of power on a 3 cell but after taking the slash to the track and running a few packs through it it started cutting out. The motor I was running was a turnigy 13.5 sensored and couldn't figure it out so I replaced the motor with a revtech 10.5. After that it did the same exact thing but kept getting worse so I put a momba max pro in and no problems since. I'm still waiting for hobby king to inspect it for warranty. |
03-08-2012, 05:50 PM | #10 |
I just took the motor off the esc and there is no difference, well now I know what ya get for $25.00 Junk!
03-09-2012, 02:44 AM | #11 |
03-09-2012, 02:49 AM | #12 |
03-09-2012, 03:38 AM | #13 |
Hobby king 60amp esc - Similar Threads | ||||
Hobby King Help | jsu101 | Electronics | 2 | 02-09-2012 01:19 PM |
Hobby King SUCKS *#@ | OfnaJoe | Chit Chat | 22 | 01-13-2012 07:29 PM |
Hobby king servo? | schoep | Losi Mini-Rock Crawler | 0 | 02-15-2011 10:12 PM |
Quark 60amp (roadster)?? | racerx | Electronics | 6 | 08-25-2007 12:07 AM |
Help finding ESC for 60amp Brushless! | rbgerrish | Electronics | 9 | 12-21-2006 10:11 PM |
