02-29-2012, 09:25 AM | #1 |
Newbie Join Date: Feb 2012 Location: South Africa
| Help needed with ESC recommendation.
Back Story is Here: Help this Newb to make his rig SUPER ! Don't know a damn thing (yet) about cralwer ESC's, and didn't think I was going to have to swot up on them this early in the fight. So I need some help. What ESC do you recommend for the following vehicle/use ? Truck in question is a 1/8th Scale Redcat Knock-off with Dual M.O.A. Beiji Guang 540 100t brushed motors. (I don't know any other specs about the motors, nor does google) Battery in use is a 2S Lipo, and everything is still controlled via the standard 3ch Tx/Rx. I don't mind spending some bucks (will always use it on future trucks), but I also don't want to buy the ESC they used to run the Mars Rover, if you know what I'm saying. So, what says you ? Last edited by Andre N; 02-29-2012 at 12:06 PM. |
02-29-2012, 10:08 AM | #2 |
| Re: Help needed with ESC recommendation.
Tekin FXR Castle Sidewinder V2/SCT Castle Mamba Max Pro |
02-29-2012, 11:01 PM | #3 |
Thanks. I'm reading up on them as we speak . . err . . type. (so far the Sidewinder looks promising) I also got a heads up for the Holmes BRXL. Another 2 quick newb questions: None of these ESC's (atleast the ones I've read up on so far) has leads to run 2 motors, only output for one. I'm assuming it's as simple as making up a Y-Splitter and then run both motors off of the one output ? And when it says an ESC can handle upto a 35t motor for instance. Does that then mean it can handle 35t - 1000t motors, but not 0t -34t motors ? Thanks in advance. . |
03-01-2012, 12:14 AM | #4 |
Yea when running dual motors without an electronic dig you would just make a Y off the motor leads. Keep in mind that your rear motor will need to spin the opposite direction than the front. There are a couple ways to handle that, simplest is to run + to - on the rear motor or you can spin the end bell of the motor 180 degrees to reverse motor rotation. You will also want to make sure that your motors both have 0 or positive timing for their correct direction of rotation. You are correct, when a motor limit is set at 35t then you can run anything 35t or above. |
03-01-2012, 04:07 AM | #5 | ||||||||||||||||||||||||||||||
OK, so I've read up on all the ESC's that were recommended, (and some that weren't) Pulled up this little schematic of the ones I liked. (coincidently it was the exact ones that were recommended. Thanks Guys.)
I've decided to go for the Sidewinder, not only for the price, but for the way I'm going to run things. I'm going to get a CC BEC to run my current servos. They are of unknown origin, and run on 4.8v currently, and when ever I upgrade, I know I will be able to run whatever I get via the BEC. So, to make the BEC work on the volts I currently, and in the future need, I'm going to have to get the Castle link. So that's already the BEC and Castle Link in my Pocket, so I don't need a ESC with a proper BEC at this time, and having the Castle Link, it only makes sense at this time to buy a ESC that can be Configured via the Castle link. So that kinda makes the Sidewinder fit the criteria. My Heart says Mamba Max, but sanity says the Sidewinder will fit the current (No pun intended) situation. I'm sure that one day when I do a "Proper" Super, a Mamba or Tekin will make their way in there. Anyone see any flaws or holes in my reasoning ? I'll also be buying everything via Tower Hobbies. (I've dealt with them before, and their shipping to S.A. is quick, and I'm also buying a bunch of tools/lugs/wire/odds and sodds while I'm already paying for shipping, and they have everything I'm looking for). Just to Confirm, this is the Current Sidewinder SV2, that I should be buying and they just have an old/wrong pic on there ? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAUHP&P=ML Am I missing anything, or am I sort of on the right track here ? . | ||||||||||||||||||||||||||||||
03-01-2012, 09:51 AM | #6 |
Pebble Pounder Join Date: Feb 2011 Location: Burnaby, BC
You might want to look into dual ESCs for your rig. I ran a super with MOA and 1 esc, and the clod stall (rear wheels basically stop moving in a climb) was awful. I never ran dual ESCs, but I believe the idea is each ESC delivers full power to the motor, whereas a single one has to split it between the two, and there is more resistance on the rear motor in a climb. You can correct it a bit with a different (slower) pinion on the rear. If you run dual ESCs, you will need at least a 3 channel radio, but then you gain the advantage of being able to setup front/rear dig, etc. Something to look into for sure. |
03-01-2012, 10:14 AM | #7 | |
| Re: Help needed with ESC recommendation. Quote:
I did run dual 35T's off an older Mamba Max ESC with a servo dig & it was fine, but the MM is a little more robust than the SW. I now run dual ESC's & dual 35T's off a Futaba 3PM-x using a WantAmix adaptor. Much better than a servo dig. | |
03-02-2012, 01:34 AM | #8 | ||
Also, to be able to do digs is not even on my mind at this point. No comps or serious wheeling in South Africa (yet). Quote:
Anyhoo, pulled the trigger on the Sidewinder, will see how it works out. Thanks for all your comments,ideas and recommendations. . | ||
Help needed with ESC recommendation. - Similar Threads | ||||
need a motor esc recommendation.. | 4drmopar | Newbie General | 9 | 04-07-2010 08:01 PM |
Motors & ESC....What is a good budget recommendation | y2kgtp | Newbie General | 18 | 12-22-2009 02:15 PM |
Took Kit Recommendation Wanted/Needed | getoutandplay | Losi Mini-Rock Crawler | 3 | 11-29-2008 08:04 AM |
need recommendation on esc for KD 36-12xl | aashu | Electronics | 13 | 11-20-2008 11:08 AM |
