Thread: scx10 dual motor mount and esc?
Old 03-20-2012, 09:09 AM   #1
Default scx10 dual motor mount and esc?
Been doing a lot of searching but I can't find the answer to my question. I am currently running Tekin fxr and a 45t motor with stock gears and a 3s lipo with 2.2's. It seems I have lost a lot of my power and torque I used to have. I have switched out my motors several times for different reasons but nothing changed when I did. I was wondering if I went with a dual motor mount If that would help the low end power and still keep the same speed. Also my biggest question is can I run the dual motors wired into on fxr esc?
jgammill is offline   Reply With Quote
Old 03-20-2012, 09:19 AM   #2
Default Re: scx10 dual motor mount and esc?
Before you go buying all that stuff, try a smaller motor pinion or a larger spur gear.
Szczerba is offline   Reply With Quote
Old 03-20-2012, 10:11 AM   #3
I've already tried those and all it seems to do is slow it down without any noticable increase in torque.
Old 03-20-2012, 10:12 AM   #4
x2. those dual motor mounts just add alot of unnecessary weight up high
benoj is offline   Reply With Quote
Old 03-20-2012, 10:15 AM   #5
I wonder if my battery could just be getting weak. It is probably 2 years old now and been used quit a bit.
Old 03-20-2012, 12:18 PM   #6
My lipos already feel weak and that's after 1 year.Recently i bought the turnigy nano 800 mah 45-90c and wow what a difference.
jvella is offline   Reply With Quote
Old 03-20-2012, 12:40 PM   #7
Might try a new battery or a new motor (or one that has been freshly rebuilt). Even if they are borrowed from a buddy, just to test.
Try recalibrating your ESC/Radio?
Old 03-20-2012, 01:38 PM   #8
I know it's not the motor, I have had 3 or 4 different ones on it testing and they all act the same. I just ordered a new battery I guess I will see if that helps.
Old 03-20-2012, 01:40 PM   #9
Does anyone know, if I was to run the dual motors, if I can run them on 1 Tekin fxr, and if there is a certain way to wire them up.
Old 03-20-2012, 06:29 PM   #10
Just y the motor wires off the Fxr to the motors. But seriously one good motor is all you need.
korn_2956 is offline   Reply With Quote
scx10 dual motor mount and esc? - Similar Threads
Dual motor mount good or bad? TW31 Axial Wraith 1 02-10-2012 07:44 AM
Dual motor mount....Anyone tried it yet? 93-12smoke Axial SCX-10 9 08-19-2011 07:02 PM
single motor esc or dual motor esc jwo Electronics 0 01-20-2010 11:42 PM
dual motor mount for ax10? stikkimikki87 Axial AX-10 Scorpion 3 02-29-2008 11:15 PM
