04-18-2012, 10:32 AM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: bay area
| Traxxas tqi not calibrating with my tekin fxr
Hi I have a traxxas tqi 2.4ghz remote, I got it to bind with the reciever but I can't get it to calibrate with the esc. I can use my link remote also from traxxas but I'd like to use my tqi. Anyone have any suggestions and yes all the throttle settings are zeroed out on the remote Sent from my DROIDX using Tapatalk 2 |
04-18-2012, 11:30 AM | #2 |
Newbie Join Date: Jun 2011 Location: Kent
| Re: Traxxas tqi not calibrating with my tekin fxr
have you tried changing it to a diferent mode. I had trouble with it working on my mini 8ight untill I switched it to mode 4 |
04-18-2012, 12:17 PM | #3 |
I haven't tried that but I'll tinker with it more when I get more time Sent from my DROIDX using Tapatalk 2 |
04-18-2012, 12:51 PM | #4 |
| Re: Traxxas tqi not calibrating with my tekin fxr |
04-18-2012, 03:36 PM | #5 | |
| Re: Traxxas tqi not calibrating with my tekin fxr Quote:
In the transmitter, -Throttle trim to "0" -Throttle sub-trims to "0" -Throttle EPA's to 100%. You may need to mess with "neutral deadband". If you "zeroed out" all throttle settings, you won't get anywhere. What LED's show up on the FX-R? | |
04-18-2012, 07:10 PM | #6 |
Try doing reverse first, if your throttle channel is backwards it will never go. If that doesnt help then plug a servo into the throttle channel and see what is going on. |
04-18-2012, 11:16 PM | #7 |
So I got it working. I think theres a glitch within the tqi cause it calibrated and worked when I was in the throttle channel setup but it stops working when I go back to the home screen but at least it works and I just updated the link app so maybe that fixed the issue. Sent from my DROIDX using Tapatalk 2 |
Traxxas tqi not calibrating with my tekin fxr - Similar Threads | ||||
Mamba Max , Tekin FXR or Tekin FXR PRO? | TheHeadHunter | Electronics | 21 | 06-21-2012 08:15 AM |
traxxas 3ch tqi | rawpwr7 | Electronics | 2 | 03-07-2012 03:33 PM |
Tekin FXR, 3S LiPo, Traxxas 27mhz receiver | mpmackenna | Newbie General | 9 | 01-08-2010 06:28 AM |
Tekin FXR and FXR-pro ESCs in stock | JohnRobHolmes | Holmes Hobbies | 35 | 09-17-2009 09:40 PM |
