05-06-2012, 02:23 AM | #1 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
| how do i make lee ermey remote control?... updated with pics of how i did it!!! 6/3
ok so im doing a 1:6 willys build and i have a talking r lee ermey action figure, he talks when you push the button on his back . i measured the voltage at the button after i tore him apart... it jumped up to like 3.4 volts ( he runs off three 1.5v button cells). i need to make him talk remotely somehow.... need some advice on how to go about it. if possible id like to stuff all the electronics in his body and be able to hit a remote keychain or something to make him talk. i thought about something like them remote fart machines to gut for parts or maybe a really small rc something or ?... how do i remotely bridge the connection momentarily on his push button? i cant use a channel on my reciever cause im already using all 4 for other things. im decent with electical circuits but im no guru... should i use physical means to make something push the button or can i just rig up some wires from another device to the push button on ermey to activate it? Last edited by brandonwalsh420; 06-03-2012 at 09:15 PM. |
05-06-2012, 08:23 AM | #2 |
Newbie Join Date: May 2012 Location: Houston
| Re: how do i make lee ermey remote control?
you could put a limit switch on some part of your steering making a simple connection parallel to the doll button, then when you make a full turn in one direction it triggers the button.
05-06-2012, 10:08 AM | #3 |
Quarry Creeper Join Date: May 2004 Location: SW of Chicago
There are little hobby kits that have an IR keychain transmitter and small reciever that would work. Kind of like the RC4WD winch controller. Here's one that was ment for automotive applications, but might work if the reciever is not too big. FRYS.com*|*Logisys You could also search the toy isles. I have a small toy truck that came with an IR Rx that activated an alarm on the truck, beaped a horn or made the truck drive for 10 feet. |
05-06-2012, 04:03 PM | #4 | ||
| Re: how do i make lee ermey remote control? Quote:
05-06-2012, 04:33 PM | #5 | |
05-06-2012, 07:36 PM | #6 | |
heres some pics of his guts... maybe they will help trigger some ideas... | |
05-06-2012, 08:10 PM | #7 |
whats your budget?
05-06-2012, 10:17 PM | #8 |
| Re: how do i make lee ermey remote control? i was hoping to be able to do it for 40 bucks or so... less would be nice tho... Last edited by brandonwalsh420; 05-06-2012 at 10:20 PM. |
05-06-2012, 10:20 PM | #9 |
Why not have it wired into the truck? You already have a remote, why complicate it by adding an additional remote?
05-06-2012, 11:47 PM | #10 |
| Re: how do i make lee ermey remote control? |
05-07-2012, 12:11 AM | #11 |
| Re: how do i make lee ermey remote control? i already have all 4 channels doing something else on the remote... ideally it would work off of a keychain thing kinda like on the remote fart machines... doesnt seem too complicated... but im not sure how to make it work...
05-07-2012, 12:20 AM | #12 | |
| Re: how do i make lee ermey remote control? Quote: | |
05-07-2012, 01:34 AM | #13 |
MODERATOR Join Date: Oct 2010 Location: RC Land
Get one of those remote farting gag gift things. Mount the internals to the key fob control in your remote TX and record whatever you want over the farting noise chip on the RX unit for the toy. One of these Amazon.com: Remote Control Fart Machine 2- Electronic Farting Gag: Toys & Games You should be able to hook it to a smaller speaker? Or use the hand controller technology and adapt the RX part of the fart toy and adapt it with the record and playback part of this... Amazon.com: 10 Second Recordable Sound Chip for Make Your Own Stuffed Animals: Toys & Games Possibly something adaptable from here? voice recorder,Animal Sound Caller,Talking Gifts,Talking Photo Albums,Talking Photo Frame- TERS ELECTRONIC LTD http://www.lookmycoach.com http://www.cheapjerseystimes.com http://www.cheapjerseysfine.com http://www.cheapjerseys-shopping.com http://www Or here? China Recordable products,sound modules,voice recorders,sound books,toy voice recorders Catalog - Saike Tech. Co., Ltd. |
05-07-2012, 08:02 AM | #14 |
Sounds like you don't want to use your remote control to do this because you are out of channels, but if you upgraded to transmitter with more channels, I could modify one of my remote switch for LEDs to have a relay output. There would be two wires that you would solder to the two contacts of the existing switch. Then every time you clicked the channel, it would be the same as pushing the button.
05-07-2012, 02:10 PM | #15 | ||
then i thought what if i make a small motor from something like a zip zap move a small peice of metal on an arm to complete the connection between 2 pins (ermeys button). this would be activating his switch through physical means. doing it electricly would be easier but i dont want to fry his electronics,... doing it physicly would be more work and probly take up more space but theres way less risk of frying his circuit... if i use the zip zap i need to replace the battery with something better because the one in the car only holds a charge for a short period of time (no big deal to swap the battery though, ive done it before with a tiny lipo) Quote:
could i just hook a relay up to the speaker on the fart machine?... or can i hook up the speaker wire to a tiny motor and make it complete the circuit through physical means? (like stated above) thanks for the help guys, i really appreciate it | ||
05-07-2012, 03:45 PM | #16 | |
8-15 volts can be modified if needed. Its a kit, a different regulator can be bought. | |
05-07-2012, 03:48 PM | #17 |
06-03-2012, 07:33 PM | #18 |
so i did make it all happen... thought i would post some pics...used a small coke can rc i got on ebay for 8$... it has aboult a 10ft range which im fine with... made the controller smaller so it looks better when its velcro-ed to my controller... ... let me know what you guys think |
how do i make lee ermey remote control? - Similar Threads | ||||
First remote control ever invented... | justinart24 | Chit Chat | 3 | 04-13-2011 08:38 AM |
remote control ? | camobob | Redcat Crawlers | 9 | 02-22-2010 09:59 AM |
Which Remote control | Jmterminator | Newbie General | 15 | 01-14-2009 07:03 PM |
Remote Control Fishing | roktoy | Chit Chat | 4 | 01-13-2008 02:01 PM |
Remote Control Range | smtv | Newbie General | 8 | 11-27-2007 02:42 PM |
