05-12-2012, 11:22 AM | #1 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| plasti-dip batteries
Is there any reason not to dip nimh and nicd packs? I figure lipos are a no no as tthey heat up alot more then the othets do.
05-12-2012, 11:54 AM | #2 |
My lipos don't heat up. Over drawing any pack will heat it up, regardless of composition. For nimh/nicad, some dielectric grease around the terminals will be enough to prevent corrosion. If kept up with. Same for lipos. All batts are "waterproof" for the most part, or else the stuff inside would come out. It's the corrosion on the terminals that's the main issue. |
05-12-2012, 12:55 PM | #3 |
| Re: plasti-dip batteries
Well i should explian further, i was give a couple 7.2packs made from individual cells, i anm re making these packs and thought i would pd them.
05-12-2012, 01:00 PM | #4 |
Structurally something else may hold better then plastidip to seal the edges. Don't see why not.
05-12-2012, 01:26 PM | #5 |
| Re: plasti-dip batteries eggcellent
05-12-2012, 02:20 PM | #6 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
First question is, why?
05-12-2012, 03:06 PM | #7 |
When I made NiCD/NiMH packs, I just wrapped cells together with 3/4" fiberglass packing tape. Clear heat shrink is also OK. Don't worry about waterproofing. |
05-12-2012, 03:23 PM | #8 |
Nickel cells get hot under heavy load and near the end of useful discharge, insulating them in plastidip won't let them cool down
05-12-2012, 07:30 PM | #9 |
I painted the ends with and left the bodies alone.
05-12-2012, 08:24 PM | #10 |
| Re: plasti-dip batteries |
05-12-2012, 08:36 PM | #11 |
Shat, i never thought of that....guess i better slit some vents in.
plasti-dip batteries - Similar Threads | ||||
Plasti Dip Help. | Butcherinhd | Tools, and Procedures | 14 | 09-22-2011 09:57 PM |
Plasti-Dip | Veritas | Electronics | 4 | 05-19-2011 11:18 PM |
plasti dip or rubberize it | iwantoffroad | Electronics | 6 | 01-03-2007 08:15 PM |
Plasti Dip? | KENNYKILLER14 | Electronics | 3 | 01-03-2007 08:13 PM |
Plasti Dip EVX | John Deere | Electronics | 13 | 02-09-2006 09:11 PM |
