06-04-2012, 11:15 AM | #1 |
Quarry Creeper Join Date: Jun 2007 Location: Inthe back of JACK IN THE BOX!!!!
| 13.5 brushless motor ?
Ok guys i'm new to the brushless world so here i go. I bought a brushless system and stuck it on a r2 tranny with a 20 tooth pinion but my old r2 had brittle gears causing the gears to explode and make the motor not turn wedging it stuck. I replace the gears and all but now the motor just goes sometimes and most of the time it doesn't, i do full throttle and it works momentarily but in low or 5 percent throttle it just makes a small noise and quits. Did i fry the motor??
06-04-2012, 03:29 PM | #2 |
| Re: 13.5 brushless motor ?
make sure the sensor wire is fully plugged in
06-04-2012, 04:38 PM | #3 |
That is the first thing i checked and it looks ok i even removed it and plug'd it again and still no go.
06-04-2012, 04:51 PM | #4 |
Rock Crawler Join Date: Nov 2009 Location: poteau
Uuplug the sensor and see if it acts the same. If it does its either the sensor cable bad or the sensor ring in the motor is fried.
06-04-2012, 04:57 PM | #5 |
Rock Crawler Join Date: Jun 2009 Location: summertown
Sounds like you Melted the stator when the tranny bound up. Pull the screws out of the endbell (shaft end) and see if the wire coating inside there is melted. You have to look closely sometimes, you may even need a small flashlight so you can see inside. |
06-05-2012, 08:19 AM | #6 |
I think i melted the ring sensor at the back end as i was told, I ended buying another motor because the motor i have has a irreplaceable sensor bell. I tried to pull the bell but no luck it feels like it is part of the entire motor housing. Thank's guys for the responses and help it is greatly apreciated. |
06-05-2012, 04:48 PM | #7 |
What type of motor do you have?
13.5 brushless motor ? - Similar Threads | ||||
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? | THE CRAWLER KING | Newbie General | 6 | 08-22-2010 07:10 AM |
Novak Releases "The Goat" brushed/brushless esc and sintered brushless motor | Rockpiledriver | Electronics | 70 | 09-26-2007 05:59 PM |
