06-05-2012, 06:46 PM | #1 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
| Setting CC BeC - but not using CC ESC
I am installing a Tekin RX but will be using a CC BEC. I do have CastleLink. Can I set my BEC to 6.0V even though Im not using a CC ESC. If so, how ?? |
06-05-2012, 06:52 PM | #2 |
| Re: Setting CC BeC - but not using CC ESC
Plug the CC BEC into the CC Link, set the voltage, save. You "may" need to plug the rig pack in to do it (the USB supply is not enough to power the BEC & ESC). |
06-05-2012, 09:06 PM | #3 |
I was hoping it would be that simple. Thanks
06-06-2012, 04:45 AM | #4 |
Pebble Pounder Join Date: Mar 2012 Location: Warren, Mi
Nothing to it. I had to plug the battery into the rig for Castle Link to read my BEC. Don't forget the save part, on the bottom right of the castle link program, under device settings. Click update device once you change the voltage output to what you want.
06-06-2012, 08:06 AM | #5 |
gracias.
Setting CC BeC - but not using CC ESC - Similar Threads | ||||
Need info for best BEC voltage setting. | AgentXXX | Electronics | 6 | 08-29-2009 05:51 PM |
can a 12v fan work w/ 6v bec setting? | driftin90 | Electronics | 2 | 08-29-2009 12:15 PM |
Voltage setting on CC bec - need help! | papabash | Electronics | 6 | 08-09-2009 05:36 AM |
setting output on a bec? | Dubs Chops | Electronics | 2 | 01-23-2009 12:11 PM |
CC BEC setting for HS645MG | 4RnrRick | Electronics | 5 | 06-06-2008 08:53 AM |
