Thread: servo issue: recommendation?
Old 06-17-2012, 10:18 AM   #1
Default servo issue: recommendation?
first of all the servo is a solar servo 772 which only costs $23 new so i know the first answer will be buy a new servo!
given that let me describe what i'm seeing. i was running it in my basher the other day and it worked for awhile then just stopped. i notice that if i pulled on the wheels then the servo would respond for a couple seconds then go out again. i let it sit for a day thinking it was overheated but the same thing. it will respond for a short time if i tug on the wheels.
the setup i had when i first ran it was: bully moa rig, running the servo on a cc bec set to 7.4v.
i pulled apart the servo today and the gears look fine and i didn't see any scorch marks on the board. it almost seems like something is hang up in the motor.
any chance of saving a $23 servo???
jebster is offline   Reply With Quote
Old 06-17-2012, 10:25 AM   #2
I think it may be inside the motor and it not getting a good electrical connection and while turning it it may be cleaning the contacts enough for a quick connection, I would just get another one and keep that one for spare parts like the case and gears
benoj is offline   Reply With Quote
servo issue: recommendation? - Similar Threads
Servo issue Ur2respect Electronics 14 11-14-2012 04:08 PM
AX 10 Servo Issue cmlooner33 Electronics 3 03-07-2012 06:41 PM
non digital servo recommendation m0nster Electronics 3 01-17-2011 10:22 AM
Servo issue, help please! Drvnbeing Electronics 0 03-27-2010 09:31 AM
Servo Recommendation DKNguyen Electronics 7 11-29-2007 11:16 AM
