06-20-2012, 07:03 AM | #1 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
| losi mrc xcelorin issue
i just bought a losi mrc from a member on here it is a new build it came rtr minus the radio so when i received it i got my losi radio and went to bind it and when i do so i get steering but no forward or reverse what could be the issue? i have never had a losi i did run a jumper wire from the motor to the battery like on a moa and when i do the motor barley turns and makes a horrible noise and thats it. kinda sounds like its binding badly but its not you can turn the wheels smoothly but the motor is really hot.
06-20-2012, 10:09 AM | #2 |
| Re: losi mrc xcelorin issue
1-You CAN'T jumper a battery to brushless motor like you can with a brushed motor! 2-Did you calibrate the ESC to the RX? You do that after the TX & RX are bound. |
06-20-2012, 10:15 AM | #3 |
Is it the sensored version? If so, do you have the sensor cable plugged in properly? You might try reversing the throttle channel on your radio, then recalibrating.... |
06-20-2012, 10:57 AM | #4 |
it is sensored . how do you calibrate the radio to it? this is the first time ive ever had problems binding a truck
06-20-2012, 11:31 AM | #5 | |
| Re: losi mrc xcelorin issue Quote:
Calibrating is setting up the ESC to the RX. Typical is like: 1-Turn on TX 2-Hold full forward on TX & power up the ESC 3-Wait for "chime" 4-Go to full reverse in TX 5-Wait for "chime" 6-Go to neutral on TX 7-Done. | |
06-20-2012, 11:48 AM | #6 |
| Re: losi mrc xcelorin issue |
losi mrc xcelorin issue - Similar Threads | ||||
Losi Xcelorin Sensored ESC/Motor Combo for the MRC! | JatoTheRipper | Losi Mini-Rock Crawler | 123 | 05-27-2010 08:48 AM |
Losi Xcelorin motor/esc in a Gatekeeper MRC | Hatteras Cast | Losi Mini-Rock Crawler | 0 | 04-01-2010 10:46 PM |
Losi MRC Steering issue | llinneman | Losi Mini-Rock Crawler | 2 | 09-23-2008 09:15 AM |
