Thread: Eiger Terra Claw 55T ESC Combo WONT WORK! SOLVED
Old 07-17-2012, 01:43 PM   #1
Question Eiger Terra Claw 55T ESC Combo WONT WORK! SOLVED
Hello
Today i got a problem with the Eiger ESC, when i try to go forward it only "beeps" very silent but i can drive backwards. When i drive backwards for a while i can out of nowhere go forward for about 2 sec and it slowly slows down to stop. But i can go backwards again and do this all i want. Go backwards, go forward for about 2 sec, over and over again. I've checked the connections, motor and i used another ESC to check if it's the esc or reciever/transmitter, but i've found out that it is the goddamn ESC. Anybody with the same problem or ever experienced it?
It all started when i tried some rock crawling with my new tyres and it slowly stopped and i thought it was the battery because i had used it all day.
Thanks for reading and sorry for bad English/grammar etc....
Lars Erik
Maglizard is offline   Reply With Quote
Old 07-18-2012, 06:19 AM   #2
Default Re: Eiger Terra Claw 55T ESC Combo WONT WORK!
Nevermind, It was moisture inside the ESC and i just cleaned it with electronic spray and it worked again
Tags
crawling, eiger, esc, rock, terra claw 55t
Eiger Terra Claw 55T ESC Combo WONT WORK! SOLVED - Similar Threads
RC4WD Modified 55t, Novak Terra Claw 35t Problems...HELP! Big Tex Electronics 11 06-20-2012 10:08 AM
Novak Terra Claw Crawling Brush Motor 55T barshots Redcat Crawlers 12 03-05-2011 05:37 AM
Axial XR10 steering link and Terra Claw 55T motor issue beb Axial XR10 12 01-28-2011 06:04 AM
Novak Terra Claw 55T motor question. arctichorse Electronics 2 01-14-2011 12:47 AM
