07-23-2012, 04:41 PM | #1 |
Rock Stacker Join Date: Jul 2010 Location: rosemount
| Problems
i have a novak goat 3s esc and a 18.5 turn balistic crawler brushless motor. the problem is its like the motor is locked up but it still spins roughly . did i fry the motor or is there a fix???? thanks for the help in advance!!
07-24-2012, 12:29 PM | #2 |
| Re: Problems
so out of 30 some people no one has a clue????????????
07-24-2012, 12:39 PM | #3 |
It's not something that can be diagnosed from a simple forum post. But here are some ideas... Try motor on a different esc or vice versa. Take apart the motor and check for any debris. Check motor bearings.
07-24-2012, 01:06 PM | #4 |
| Re: Problems
Sounds like a sensor issue, make sure your sensor wire is firmly plugged into both ends...Might be time to try a new sensor wire. If that doesnt work we will need more information than its locked up but spins roughly. |
07-24-2012, 04:03 PM | #5 |
| Re: Problems
thanks guys ill try that tonight
07-24-2012, 04:29 PM | #6 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Problems
Sounds like your motor is shorted, if it feels harder to turn than normal then most likely it's done. Shorting the windings is the same thing as applying brakes, so if you've got brakes while not hooked up to the ESC that's bad.
07-24-2012, 10:10 PM | #7 |
| Re: Problems
that kinda sounds like what it is cause when i turn it in a full circle it stops like 6 times
07-25-2012, 05:26 AM | #8 |
Rock Stacker Join Date: Oct 2007 Location: MD, USA
| Re: Problems That's what brushless motors are supposed to feel like off-power. If they don't have six stops, THEN something is wrong. What is it doing when you try to run it? What you are describing, if you are talking about stuttering on-power, sounds like a bad sensor wire to me. Try a different sensor wire and report back.
07-25-2012, 12:17 PM | #9 |
| Re: Problems
when i ran it in the chassi it would try to move but just stop right away. wen i took it out it would do the same unless i helped it along and it sonded rogher and the 6 stops feel rougher than usual , this is so hard to describe
07-25-2012, 02:16 PM | #10 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Re: Problems
You probably melted the stator. Good news is you can buy another from Novak. http://www.shopatron.com/products/pr...6.0.0.0?pp=10& Last edited by KBrog; 07-25-2012 at 02:18 PM. |
07-25-2012, 02:20 PM | #11 |
Rock Crawler Join Date: Jan 2012 Location: st.louis
07-25-2012, 04:40 PM | #12 |
| Re: Problems |
07-26-2012, 11:04 AM | #13 |
| Re: Problems
I have brushless motors that you clearly have to turn the motor hard and it has several steps when rotating. I have others that turn as smooth as a brushed motor when not hooked up. It all has to do with the magnet size/strength and the motor design/build. I'd pull the ends off, clean it up, put it all back together and see if it's still not working correctly. The Novak is a pretty beefy motor so it probably should feel like there are steps or stops when you turn it. Again, I don't have one so I can't say for sure. |
07-26-2012, 11:52 AM | #14 | |
| Re: Problems Quote:
Motors designated with turns (17.5, 13.5, etc) are typically wound like this and will feel notchy when you spin them. They are wound similarly to a brushed motor. Motors designated with kv ratings are typically wound like this and feel smooth when you spin them. Notice the copper looks like it was wadded up and epoxied into shape. | |
07-26-2012, 12:00 PM | #15 |
| Re: Problems
Nice post Duuuuuude, that explains a lot.
07-26-2012, 12:03 PM | #16 |
| Re: Problems |
07-26-2012, 12:39 PM | #17 |
| Re: Problems
Are you sure that you have the phases correctly wired between the ESC and motor? Try running it without the sensor wire plugged in and report back what happens.
07-26-2012, 01:12 PM | #18 | |
| Re: Problems Quote:
Great explaination and pics! Also, you can't run a sensored motor w/o the sensor wire? Correct me if I'm wrong? A burnt up stator is easy to tell - the wires or connectors look burnt... It smells burnt. If it doesn't work with a new or different sensor wire something worse is wrong, and/or it could also be the ESC. Could also be that you have connected the motor wires out of phase like the guy above stated. Is this Novak system new to you - have you used it before w/o any problems? Last edited by DudeWalker; 07-26-2012 at 01:16 PM. | |
07-26-2012, 01:29 PM | #19 | |
Agreed that decent brushed motors have some too. | |
07-26-2012, 01:55 PM | #20 |
| Re: Problems
Also depends on slotted vs slottless, plus there will be more than 6 spots depending on how many poles/slots the motor has. Not all of them will feel the same. If it feels hard to turn, or 'sludgy' then chances are the stator is shorted.
Problems - Similar Threads | ||||
Just went out to the track for the FIRST TIME. Problems Problems Problems | flyingrc | Non Crawler RC's | 4 | 07-23-2012 10:19 PM |
Problems problems problems hope it's worth it in the end | TJcreeperJEEP | Venom Creeper | 9 | 12-22-2009 04:54 PM |
Problems....... | 4DIGG | Newbie General | 5 | 11-07-2009 07:21 AM |
Problems | scrub | Electronics | 2 | 05-27-2007 11:26 AM |
