Thread: Servo wired directly to a TX
Old 07-29-2012, 12:33 PM   #1
Default Servo wired directly to a TX
Is there any way to wire up a servo so that it is hard-wired to the TX?
Greatscott is offline   Reply With Quote
Old 07-29-2012, 12:39 PM   #2
Default Re: Servo wired directly to a TX
Just wiring it up??? I highly doubt it. You will likely need a way to convert the TX signal to something the servo understands. You also need to supply power to the servo.
Actually, you can do almost anything, but is the potential cost worth it??
Curious, why do you want to do this??
Charlie-III is offline   Reply With Quote
Old 07-29-2012, 12:46 PM   #3
I am making a pole-mount for my GoPro that I can rotate. I can wire up a cheap TX/RX combo with batteries at both ends, but I am trying to keep the weight down, keep the wiring to a minimum and use as few batteries as possible.
I do have a couple of old TRX AM radios, what would happen if I soldered the RX antenna directly to the the TX's antenna output?
Old 07-29-2012, 12:50 PM   #4
You'd have an RC car from the 60's.
Cheatin is offline   Reply With Quote
Old 07-29-2012, 02:58 PM   #5
I would NOT suggest connecting a TX antenna to a RX antenna.
No reason you couldn't use a cheap battery to power the RX and plug in a cheap servo to do the rotation..
Old 07-29-2012, 06:52 PM   #6
Tzi
Thats just gold!
Yep, you can do it using a servo-tester.
That way batteries would be only be needed at one end.
HobbyKing R/C Hobby Store : Servos and parts>Servo Tester
You could use the cheapest one and put it in a nice box with a knob for easy use.
HobbyKing R/C Hobby Store : Simple Servo Tester
Tzi is offline   Reply With Quote
Old 07-29-2012, 07:24 PM   #7
Originally Posted by Tzi View Post
Thats just gold!
Wholly crap!!!! I've never used a tester so using one never crossed my mind, SCHWEET!!!!
Thanks!
Old 07-29-2012, 07:29 PM   #8
Tzi
Your welcome.
Servo wired directly to a TX - Similar Threads
Servo directly to battery papabash Losi Mini-Rock Crawler 9 12-08-2011 02:51 PM
Direct wired servo goes wacky? Deezul Electronics 2 01-06-2011 04:29 AM
Wiring Bec directly to servo xj_man_646 Newbie General 5 03-13-2010 02:18 PM
cc bec wired to just 1 servo vdubman Electronics 7 02-10-2009 08:48 PM
Powering 5995 robot servo directly from Super Rooster kevinlongisland Electronics 6 01-20-2006 08:46 PM
