09-17-2012, 05:23 PM | #1 |
Newbie Join Date: Aug 2012 Location: Armathwaite,uk
| Rc4wd xr4/outcry esc problem (help wanted)
Hi everyone, new to the forum so iam not sure if this is the best place to post this but I need help, I went to use my trail finder 2 today and I turned it on only to find that it took off in reverse and when I tryed to go forward it just jumped around violently as if the battery was flat, so I charged the battery up and it does the same thing, if I swap the throttle and steering channels around and use the steering wheel for throttle it works fine and it makes the steering jumpy instead so it looks as if there is a problem with channel 2 on the receiver , iam running a rc4wd xr4 radio with a outcry esc/ bec with 2 mayhem servos and a rc4wd motor, any help would be much appreciated, cheers Chris
09-17-2012, 05:42 PM | #2 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: Rc4wd xr4/outcry esc problem (help wanted)
Replace you reciever. but check if there is any water damage or if ther is any dirt in the reciver.
09-17-2012, 06:37 PM | #3 |
Thanks for the reply, can the receiver go wrong that quickly? I've only had it about 3 weeks, there is no dirt in the receiver and it's never seen water. Cheers Chris
Rc4wd xr4/outcry esc problem (help wanted) - Similar Threads | ||||
Rc4wd Outcry esc | THE CRAWLER KING | Electronics | 26 | 02-28-2015 07:46 PM |
Problem with two different OutCry Crawler ESC and BEC | Predator | Electronics | 5 | 01-22-2012 05:30 PM |
RC4WD XR4 problem | hlb3 | Electronics | 15 | 07-07-2011 07:31 PM |
Rc4wd outcry esc problem anyone else???? | losiredcatcrawler | Electronics | 2 | 03-08-2010 09:11 PM |
