10-01-2012, 10:08 PM | #1 |
Rock Stacker Join Date: Feb 2012 Location: Longview
| bulldog winch prob
I just bought my winch 3 days ago and used it like 3 time. and now when i try to use it. it dont do anything i looked at wires there good. But it ust wont work i ned help thanks
10-02-2012, 08:54 AM | #2 |
| Re: bulldog winch prob
Sometimes the controller fails. Since the winch consists of two major parts, we can do a little trouble shooting. Unplug the motor from the controller. Feed six volts into the winch and the winch should turn. Reverse the polarity and it will turn the other way. If indeed this works, we can assume the controller is broken and the winch is fine. If the winch didn't operate when powered by six volts, then that's your problem Since it is so new, it might be worth a trip back to the hobby shop to see if they will replace it for you. Or, if the controller is faulty, you can replace it with one that I make. Winch Controller for Radio with Three Position Channel Winch Controller for Radio with 2 Position Third Channel Higher Voltage Winch Controller Relay Driven - External Power - Winch Controllers |
10-02-2012, 10:20 AM | #3 |
I let my friend use my winch battery and i switch the plugs for him Then i forgot to switch the lugs back over and i plugged in And tryed it and it didnt work and my friend said i blew it up and broke it Could that cause it
10-02-2012, 10:22 AM | #4 |
hard for me to say. did you do the test I suggested?
10-02-2012, 10:27 AM | #5 |
No not yet but i will try that..
10-04-2012, 08:41 PM | #6 |
Idk how to do that can u explain it
10-04-2012, 09:01 PM | #7 |
The idea is to get a voltage onto the winch motor. See where I have the winch controller next to the connector on the winch? You need to find a way to get 6 volts into there. Can you find a way to do that? If it were me, I would take a servo connector and use it to get the power from a receiver and feed it into that connector. If you are not comfortable doing this, please don't. Have a friend that has more experience with this kind of thing help you. Last edited by heyok; 10-04-2012 at 09:03 PM. |
10-05-2012, 03:29 AM | #8 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Contact RC4WD..... I had a similar issue and have had awesome customer service with them. That would be my advice since it doesn't seem you are to sure about conducting tests on the equipment. Sent from my Samsung Galaxy Note (Phablet) |
bulldog winch prob - Similar Threads | ||||
Bulldog winch on my honcho??? | Rocked | Axial SCX-10 | 3 | 03-15-2011 08:35 AM |
bulldog winch | krazikev | Chit Chat | 11 | 02-15-2011 07:06 PM |
