10-15-2012, 03:25 PM | #1 |
| Power HD servos
Any good? Just picked up the 1218TH for cheap. Wondering if anyone had any experience with them. 291oz for $40 seemed too good to pass up...
10-15-2012, 03:28 PM | #2 |
| Re: Power HD servos
Link? Pics? Anything?
10-15-2012, 03:30 PM | #3 |
| Re: Power HD servos |
10-15-2012, 05:07 PM | #4 |
| Re: Power HD servos
Comes in an awful fancy box. That has to account for something. |
10-15-2012, 05:41 PM | #5 |
| Re: Power HD servos
Yes it does. That box also says that it has a 2 year warranty.
10-15-2012, 06:05 PM | #6 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: Power HD servos
post up how it works, my son is hell on servos. he dont drive enough to justify buying him a high end servo. what horns fit em? Last edited by stanmondz; 10-15-2012 at 06:19 PM. |
10-15-2012, 06:09 PM | #7 |
| Re: Power HD servos
Not sure what horn fits it. I've got nothing to put it in at the moment other than some go-fasts. They would hardly be a good test vehicle for a 300oz servo. It'll most likely sit in its fancy box for a few months until I can get another rig built.
10-15-2012, 06:39 PM | #8 |
| Re: Power HD servos
i cant find that exact servo, but other power hd servos are listed as 25t futaba spline. some people say futaba don't fit though
10-15-2012, 06:59 PM | #9 |
Rock Crawler Join Date: Sep 2008 Location: Kennesaw
| Re: Power HD servos
Man they are sold out. I'd have loved to grab that for my new wraith Im doing.
10-15-2012, 07:16 PM | #10 |
10-15-2012, 07:17 PM | #11 |
| Re: Power HD servos
pretty much the same servo on ebay,different name CYS S2220 Digital metal gear servo 64g 0.18sec/60° Torque 20kg/Titanium 7.2V HV | eBay |
10-15-2012, 07:26 PM | #12 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
| Re: Power HD servos
I received one in trade awhile ago. The main (large gear) had the same issue some of the other Ti servo china gears did. The pins that hold the 2 piece gear together is not enough. I wish i could find the link to the thread where an Aussie guy put hardened drill bits in it.
10-15-2012, 10:07 PM | #13 |
Rock Crawler Join Date: Sep 2011 Location: Stanford
| Re: Power HD servos
bunch of us are using the 1501MG's in our mini crawlers with great results and been using futaba horns. these are a little stronger and faster than the hitec hs-645's.
10-16-2012, 03:37 AM | #14 |
| Re: Power HD servos
My only experience is with the 1501MG, and that doesn't quite hold up to specs. The torque figure provided is holding torque, which the servo is able to hold still against. The stall torque, which is the limit at which the servo is (almost) able to move, is waayy lower. The numbers given by the manyfacturer are (somewhat) accurate only when the servo is fed straight from a fully charged battery of the given nominal voltage of course, so the 6.0V values are representative for a ~7V feed. |
10-27-2012, 11:12 PM | #15 |
| Re: Power HD servos
Finally got to try the servo out. Good torque and speed, but a bit noisy on center. I'm wondering if maybe my voltage is a little low (technically a high voltage servo) and I need to bump it up over 6v with a bec... Otherwise, I think it'll do the job just fine. |
10-28-2012, 09:52 AM | #16 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
| Re: Power HD servos
Looks like knock off jr servo even uses same wiring
10-28-2012, 10:14 AM | #17 |
| Re: Power HD servos
What do you mean "the same wiring"? I've bought several servos with that same color code. IMO that is a good thing. Standardization keeps the confusion down.
10-28-2012, 07:40 PM | #18 |
| Re: Power HD servos
It uses jr plug is what i read but uses same case and color design as jr servos
10-28-2012, 08:18 PM | #19 |
12-30-2012, 05:03 PM | #20 |
| Re: Power HD servos
i dont see em on the site anymore. they drop em?
Power HD servos - Similar Threads | ||||
Power HD servos | el_Fernando | Electronics | 14 | 05-22-2010 07:08 PM |
Enough power for Dig and Steering Servos ? | BoredGord | Electronics | 15 | 08-17-2009 09:54 PM |
How do I power 3 servos | Tronk | Electronics | 18 | 02-05-2007 12:28 PM |
More Power For My 1/4 Servos | Azcats1 | Tamiya Txt-1 and Juggernaut | 7 | 10-03-2005 02:19 PM |
