Thread: Help: Amp draw on a 4.5 bl motor?
Old 11-19-2012, 02:49 AM   #1
Default Help: Amp draw on a 4.5 bl motor?
Hallo
I just got a 4.5turn brushless motor the weekend thanks to Pauls that swapped it for my 10.5T. Its a Novak motor running on a GTB ESC.
So what I heard was that you multiply the C-rating of the battery with the MAH (divided by 1000) to get the AMP draw the battery can handle. So Amp-draw=C x (MAH/1000)
So my 5200mah 20c batter can handle 100amp draw. But I have a Lipo alarm screaming in my ear every time I touch the throttle to quickly. So the question is what is the amp draw of a 4.5T BL motor?
Thanks
Wagenmeister is offline   Reply With Quote
Old 11-19-2012, 05:14 AM   #2
Default Re: Help: Amp draw on a 4.5 bl motor?
I think the lipo alarm is either faulty, or faulty battery itself, I'd check that stuff 1st, thats happened to me once before and it turned out to be the alarm itself
matt889 is offline   Reply With Quote
Old 11-19-2012, 05:37 PM   #3
That motor is very capable of drawing 100+ amps.
As batteries get older, their current carrying capability decreases. If that battery is more than a couple years old, it may be the equivalent of a 15C or even 10 c battery.
Manning is offline   Reply With Quote
Old 11-19-2012, 06:22 PM   #4
Got Worms?
That motor has no issue pulling 100+ amps.
You need some very good batteries to run it.
losikid is offline   Reply With Quote
Old 11-20-2012, 06:44 AM   #5
The alarm is brand new and works perfectly, it only sounds when I push full throttle and when the battery is below the safe voltage.
The battery is still good, I bought a new 3600mah 30C battery but havent run it as I was told the discharge on the 5000mah battery is more then the 3600mah.
So basically the question is which battery do I need to run full throttle on the Wraith with sand paddles.
Thanks for the help so far.
Help: Amp draw on a 4.5 bl motor? - Similar Threads
RE; amp draw "per motor" on an moa The Jackalope Electronics 3 04-05-2012 02:40 PM
AMP draw of stock motor? coreyfro Losi Micro-Rock Crawler 4 11-29-2011 05:01 PM
Motor Amp Load/draw aaugman Electronics 23 03-17-2009 08:27 AM
Max amp draw for a lathe motor? Soya Electronics 4 06-27-2008 04:03 AM
amp draw of 55t lathe motor gamer550 Electronics 3 01-19-2008 05:50 AM
