12-23-2012, 10:21 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: Under a Rock
| dual sidewinders wont calibrate to 4pl
i am having some issue with the signal from the futaba 4pl. when the dual micro sidwindrs are hooked up to a tq3 radio and reciever they work perfect and will calibrate. but when i try to use a 4pl radio on them they chime up but act like they cant find neutral to finish the initiation. when i put the fxrs back in they work on both radios. i keep getting 2 green lights on like the trim is set too far forward but when i try to adj it back i get no results no matter where i adj it to. i have been trying to calibrate them one at a time and/or together. i asked marlboroman and he had the same problem and diddnt use them because of it. so someone has had to figure this out by now. PLEASE HELP!!!!!!!!!!
12-24-2012, 05:50 AM | #2 |
Newbie Join Date: Feb 2010 Location: Columbia
Check the firmware on the sidewinders with castle link. I could not get my micros to calibrate on the newest beta firmware. Try to downgrade them to the last non beta firmware and the calibrate. I don't know if it is a futaba thing or not but that was the problem I had trying to get running with my 4pks and micro sidewinders.
12-24-2012, 07:05 AM | #3 |
| Re: dual sidewinders wont calibrate to 4pl
Have you tried reversing your throttle setting on the 4pl. Before calibration.
12-24-2012, 07:19 AM | #4 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I have two mamba micro's and I sometimes have to calibrate them one at a time, depending on firmware.
12-24-2012, 11:24 AM | #5 |
Thanks agbracing!!! That worked perfect. It will only work with the 1.32 non beta software. But my laptop offered the new version 1.38 beta i clicked on it not knowing what would happen. I wish I would have posted this sooner. I spent many hours scratching my head with frustration and screwing with the settings in the radio. I called a Castle creations tech guy 3 weeks ago about it and he had no idea. Thanks again bud!!!-------- There are some pretty fart smellers in here |
12-24-2012, 12:37 PM | #6 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
IMO, I have found that firmware upgrades in most things, not just RC, don't always help out. I never upgrade my phones, tablets, or the like. If they work, i leave them alone. Castle specifically has always given me issue when I upgrade firmware. I tend to roll them back to the oldest one available in the castle link software.
12-24-2012, 01:29 PM | #7 |
| Re: dual sidewinders wont calibrate to 4pl |
12-25-2012, 04:52 AM | #8 |
Your welcome. I scratched my head a couple hours over this same issue a couple weeks ago. I just happen to try downgrading and it worked. Merry Christmas.
12-27-2012, 06:56 PM | #9 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Just had the same problem with mine. It would give me a low voltage code when I tried to calibrate. If I just plugged it in, the ESC would eventually arm. The problem is you could tell the settings were not correct. Beta versions seem to be a pain in the rear end! Wes |
dual sidewinders wont calibrate to 4pl - Similar Threads | ||||
mamba micro pro wont calibrate | stanmondz | Electronics | 3 | 11-20-2012 07:34 AM |
Dual micro Sidewinders on JR9505 | wolfmandan62976 | Electronics | 0 | 04-16-2012 09:03 PM |
dx3.0 wont calibrate with brake for fxr | crawler_jake | Electronics | 3 | 06-14-2010 10:28 PM |
Dual Micro Sidewinders on 3s and 35t | JSmall | Electronics | 16 | 05-14-2010 01:41 PM |
Dual Sidewinders or FXR's for MOA? | ripper7777777 | Electronics | 9 | 11-10-2009 07:12 AM |
