Thread: Newbie battery question, regarding RC 4WD trail stomper
Old 12-31-2012, 07:48 AM   #1
Default Newbie battery question, regarding RC 4WD trail stomper
Hey all,
I'm looking at purchasing a RC 4WD trail stomper ready to run kit, and am wondering what battery to get. The only information in the online manual is it needs a 7.2V battery and no more than a 6cell lipo.
And not knowing much about all this stuff I have a 1/8 scale rc car which it's battery has ""Ni-MH SC2000mAh 7.2V" written on the side. Would this battery work? I asked them this question in an email but all they sent back was a link saying I could use one of there stocked batteries which was a 7.2V Ni-MH 5000mah battery. What is the difference? And will my existing battery work?
I'm a bit reluctant to buy a battery from the states coming from Australia
nathanbutcher is offline   Reply With Quote
Old 12-31-2012, 07:51 AM   #2
Suck it up!
Duuuuuuuude's Avatar
Default Re: Newbie battery question, regarding RC 4WD trail stomper
Yes it will work. I would not invest too much into 7.2v nickle batteries though, lipo is a much better option.
Duuuuuuuude is offline   Reply With Quote
Old 12-31-2012, 07:52 AM   #3
Yes, your existing battery will work. It's a little big & heavy, so down the road you may want to upgrade.
The 7.2volts looks like a minimum "nominal" voltage, so a 2S LiPO will also work.
You may need to change the pack connector, recommend NOT using Tamiya style connectors, Deans is pretty common and worthwhile.
Charlie-III is offline   Reply With Quote
Old 12-31-2012, 08:00 AM   #4
So what is the difference in the 2000mah and 5000mah? Is it the higher the number the longer run time and power output?
If the manual states it uses a 7.2v battery does this mean it could use any 7.2v battery with any mah value?
Old 12-31-2012, 08:02 AM   #5
Suck it up!
The mah rating is your "gas tank". The bigger the number, the longer the run time. Nearly any size will work.
The voltage rating is where you get your power. The higher the voltage, the more power you have on tap.
Go to RC4WD's website and research the Outcry esc, which is what comes in that kit. You should find its voltage limitations, which goes beyond 7.2v.
Old 12-31-2012, 08:05 AM   #6
Okay sweet.
Thanks for your help
Newbie battery question, regarding RC 4WD trail stomper - Similar Threads
getting the rc 4wd trail stomper batman010208 Newbie General 8 03-06-2012 09:54 PM
newbie battery question aprobert1981 Newbie General 7 03-16-2010 12:30 AM
Newbie Battery Question Again xanti Electronics 6 04-03-2009 09:08 AM
newbie battery question evaderman Newbie General 4 06-19-2008 11:31 AM
Newbie Battery Soldering Question Robb Electronics 3 10-30-2005 01:39 PM
