01-01-2013, 06:43 PM | #1 |
Newbie Join Date: Sep 2006 Location: maui
| Burnt ESC
Well burnt another ESC. Installed a castle bec on my tekin fxr and a 11.1 lipo. Ran it for a couple of days. Backed it off a little drop about 12" tall. Up it smoke it went. Ran over pulled the battery off. Checked it out ESC fried nothing else burned. So I installed another tekin fsr today. Before I plugged it in I made sure no wires were touching and all connections were correct. Plugged it in and smoked again. What could it be nothing else is burnt. How could I check my bec rx and servo.
01-01-2013, 06:55 PM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Burnt ESC
What do you mean by "Installed a castle bec on my tekin fxr"? A CC Bec is an external power source for a peripheral component...usually servos in the car game. It's completely separate from the ESC.
01-01-2013, 10:15 PM | #3 |
| Re: Burnt ESC |
01-02-2013, 12:31 AM | #4 |
Pebble Pounder Join Date: Aug 2011 Location: NSW, Australia
| Re: Burnt ESC
When you wired the BEC in, did you run it through the RX, or direct to the servo. If you ran it through the RX, did you remove the red wire from the ESC connection? Layton |
01-02-2013, 01:30 AM | #5 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
| Re: Burnt ESC
^^^ Post a pic of your setup, seems something is not right for sure
01-06-2013, 03:07 PM | #6 |
Here's some pics of my setup. |
01-06-2013, 03:08 PM | #7 |
01-06-2013, 04:25 PM | #8 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| Re: Burnt ESC
The cable that goes from the fxr esc to the radio reciever (red, white, black wires). You need to remove the red wire from the plug so it does not go from the esc to the radio receiver. You can remove it from the plug. Pretty self explanitory when you look at it. Pull up on the plastic tab that holds the red wires pin in the connector and it will pull out. Then just tape it over, etc so it won't short on anything. What is happening is the bec "and" the esc(fxr) are sending power to the radio receiver. The bec is back feeding into the esc (fxr) and hurting it. That red wire you will be removing is what powers the radio receiver and servos normally. but when you add an external bec, you need to remove it or you will have the issue that you are having.
01-06-2013, 04:34 PM | #9 |
I did take it out if u look in the first pic I cut it out.
01-06-2013, 06:36 PM | #10 |
Well put a old ESC I had laying around in my truck. Took out the bec and it worked. So I guess the new bec I put in is bad. Thank guys for tryin to help.
Burnt ESC - Similar Threads | ||||
burnt up motor #2. What do i get? | bmf24 | Axial Wraith | 24 | 09-10-2011 04:24 PM |
Axial ax-2 burnt up? | geekfreek95 | Electronics | 12 | 08-29-2011 02:42 PM |
burnt up esc/ what to get to replace novak goat 2s | custom12 | Electronics | 1 | 06-09-2010 08:45 PM |
Rooster crawler esc burnt out!!!! Help!!!! | rcracer11 | Electronics | 6 | 02-06-2009 01:18 PM |
