01-09-2013, 10:06 PM | #1 |
Newbie Join Date: Jan 2013 Location: san francisco
| 4wheeel steer help dx3s
can i use my spektum 3S for rear steer is there a mod for it or do i need a differant radio |
01-09-2013, 11:54 PM | #2 |
Pebble Pounder Join Date: May 2011 Location: under a bridge
| Re: 4wheeel steer help dx3s |
01-09-2013, 11:56 PM | #3 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Yes. Search here, there are a couple threads detailing how to set it up. Hint: search my posts. Or, use the link provided by crazy81. |
01-10-2013, 06:37 AM | #4 |
Here is an option for you to run 4WS... One of the nice things it does is give you centering and end point adjustment for the rear servo. If I'm not mistaken, your transmitter's third channel is a two position one. In that case, the second link is the one for you. 4 Wheel Steering Controller 4 Wheel Steering Controller - controlled by a two position third channel |
01-11-2013, 07:26 AM | #5 |
Or just have a few profiles on the dx3s for the same vehicle with different rear steer settings. You can also set up end points in the dx3s without extra hardware. See this thread; Dx3s 4ws and crab steer Last edited by gbean; 01-11-2013 at 07:28 AM. |
01-12-2013, 09:34 AM | #6 |
thanks forall the help
01-12-2013, 09:37 AM | #7 |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
Dude, Heyok's shiznit is plug and play, nuff said.
01-12-2013, 08:03 PM | #8 |
I would agree the heyok controller is great when you want to run a winch with the dx3s. But why add hardware when your existing hardware will do the job?
01-12-2013, 10:41 PM | #9 |
True that, but I know a lot of guys who would run 4WS would also run a winch on the same channel. At least with his controller, he can put a toggle switch on it so you can use either winch or 4WS.
01-13-2013, 12:13 AM | #10 |
True. If you want to run both at the same time.
4wheeel steer help dx3s - Similar Threads | ||||
Dx3s 4ws and crab steer | MDcrawler710 | Electronics | 2 | 11-26-2012 02:25 PM |
dx3s | lobi1kanobi | Electronics | 6 | 08-21-2009 02:55 AM |
Will Vanquish Axial High Steer Steering Knuckles make my truck steer tighter? | blue bronco | Axial AX-10 Scorpion | 3 | 08-09-2009 12:30 AM |
