01-31-2013, 11:05 AM | #21 |
| Re: 1 truck burnt down, is my other safe?
Huh go figure, you try drowning a speed control a couple times then when it finally gives up the ghost it must be the batteries fault. Play stupid games, win stupid prizes.
01-31-2013, 11:22 AM | #22 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
As a few have mentioned a 2S Lipo and 6 cell NiMh or NiCd have similar nominal voltages but a 6 cell NiMh or NiCd battery pack will charge to 9.2 to 9.6 volts (depending on the quality of the batteries and the charger), a 2S Lipo will charge to 8.42 volts. So it's safe to say the voltage wasn't an issue. Having said that, a good quality Lipo of similar amp/hour ratings can produce a lot more current than a NiMh or NiCd battery. Sometime 2 - 4 times or even more current. In the case of the OP if all things were wired up correctly (some photos of the rest of the wiring might help others here) it is highly possible that you may have over-loaded the 60 amps Tamiya ESC with the Lipo battery. Let me explain my theory more here. If I read correctly the vehicle is an "Exceed Mad Torque"? Twin Motor? Running a single Tamiya TEU-104BK? Note - Can be used with Sport Tuned Motors and 25T and above motors. FYI 2 Motors (Say 35T motors) wired in parallel = 17.5T. Why didn't it happen with the NiMh or NiCd, see my comment above. |
01-31-2013, 11:53 AM | #23 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
not sure but the op says in his first post it has a tamiya plug with the banna plugs could b that the tamiya plug melted an caused a short. had that happen a couple times what plug was on the exceed truck when it happened
01-31-2013, 03:37 PM | #24 | |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
| Re: 1 truck burnt down, is my other safe? Quote:
01-31-2013, 03:53 PM | #25 |
| Re: 1 truck burnt down, is my other safe? |
01-31-2013, 03:54 PM | #26 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
here are the facts, the battery did not burn up, the ESC did. something in the ESC failed, the chances that the battery caused your ESC to fail, so long as the battery voltage fell with in the acceptable range of the ESC, is slim to none. Lansu ESC's like the ones in the RS10XT are known to do this at random.
01-31-2013, 04:34 PM | #27 |
| Re: 1 truck burnt down, is my other safe? i haven't tried the lipo in the tamiya esc, that's what im asking, will the lipo blow this esc too? what are the specs for it. i cant find much, all ive herd is that you need an external low lipo warning which i have
01-31-2013, 05:42 PM | #28 |
Pictures of a melted piece of crap mean nothing. Answers have meaning and will help you find the cause. What s is the battery? If its 3s or above then yes it could be the culprit. If its 2s then no it didn't have a damned thing to do with it.
01-31-2013, 06:45 PM | #29 |
its a 2s. i mentioned that in the intro post
01-31-2013, 06:48 PM | #30 |
Rock Crawler Join Date: Mar 2011 Location: hampton
the lipo did not hurt the esc, something else went wrong. you said the esc had gotten wet before, wet electronic corrode, corrosion causes resistance, resistance causes heat, enough heat can melt a solder joint and the melted solder can flow to another solder joint and cause a dead short,could have been a motor arm short out and caused excessive current to be pulled through the esc and fried it. the problem had to be the esc,after the esc,or reversed polarity shooting power up the ground side. that would have caused a nice arch when the pack was plugged up though. what kind of charger are you using on your stick packs? does it display final charge voltage? if so, it should be over 8 volts on a 6cell stick pack.a 2s lipo will be 8.4 fresh off the charger. search the web for tamiya TEU-104BK on 2s lipo. you will find a few posts on tamiya club fourms where they run the esc on 2s with a alarm or cut off with no problems |
01-31-2013, 07:01 PM | #31 |
what confuses me is that literally 30 seconds earlier i ran the truck wiht a NmHi battery and it worked fine. i guess lipos have bigger balls. and my old charger did not have a display, jsut a plug. my new one does. its a thunder ac6 |
02-01-2013, 10:22 AM | #32 | |
So, bananas (the fruit) are yellow, and most XT-60 connectors are yellow, are you running XT-60's? And mistakenly calling them bananas? And the reason I quoted you and asked if you were trying to run a 3S is because in your opening post, you said you 'got this LiPo', and you asked if the ESCs in question would run on 2S, you never said the LiPo you got was a 2S. You could post up a pic of your Tamiya and battery before you plug it in, but from a picture we can't wiggle stuff around and check for tension on wires, you're going to have to be the one who needs to verify that everything's where it's supposed to be, no insulation scraped off on a sharp edge, all connectors solidly seated, etc. Best of luck to ya, Bud, wish you well. | |
02-01-2013, 11:24 AM | #33 | |
RCC Addict Join Date: Jul 2009 Location: Near Boston
So... Power (watts) = Volts x Amps and if you increase your voltage by 50% and your Amperage by 50% you are deliver 125% more watts to your poor little speedo. This probably doesn't help to much to know how it will perform on your Tamiya but at least it may help diagnose what actually happened to the Exceed. | |
02-01-2013, 11:46 AM | #34 |
Rock Stacker Join Date: Oct 2007 Location: MD, USA
2S LIPOs run fine in Tamiya fully fuctional ESCs. LIPO fire - throw in sand bucket and cover with sand if you are trying to contain it. Otherwise, get it outside ASAP and it'll burn itself out. At my local track we've got sand buckets on standby, but we have not seen a LIPO fire in a good long time. Every fire I've seen has been caused by a short or over discharge. From what I have read here, this is not a LIPO fire but a short somewhere else, and you're lucky you didn't lose everything. Last edited by DudeWalker; 02-01-2013 at 11:51 AM. |
02-01-2013, 06:17 PM | #35 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
This is what happened to my ESC when it got wet. Nearly caught the truck on fire. |
02-01-2013, 06:54 PM | #36 |
Ha....I ran my old TT-01 basher car running a 13 month old SV2/6900kv 4pole through a little puddle of water and I mean LITTLE! Well the lexan body happened to send all that water down into the tub body which I guess I was a retard for doing so but I figured at the speed I was going it would just splash out not splash INTO the freaking chassis. Long story short white smoke comes billowing out so I unclipped the body real quick unplug the lipo and let the ESC smoke itself away after flipping the car over. Lipo was fine, motor was fine, car was fine...ESC just shorted itself. I guess the SV2 isn't quite as "splash resistant" as I thought. No biggie I sent it into Castle and just traded it in for an SV3 upgrade. Thank god for electrics dropping in price now compared to years ago.... |
1 truck burnt down, is my other safe? - Similar Threads | ||||
Burnt out of crawling??? | country_crawler | Chit Chat | 30 | 08-26-2010 08:44 PM |
servo burnt up | boostedg60rado | Electronics | 2 | 07-09-2009 04:13 AM |
wallmart gun safe...Really safe? | xxizzer421xx | Chit Chat | 10 | 10-11-2007 02:42 PM |
Burnt' Crawlmaster? | Mad4Rnr | Electronics | 33 | 07-29-2007 09:59 PM |
