03-03-2013, 09:37 AM | #41 |
Newbie Join Date: Jul 2012 Location: The I.E.
| Re: Tekin ROC412 knocking noise
I too have the same issue only its on the RS as well. I am using the 223 FW from hotwire with drag brake on. running a 13.5 motor sensored.
03-03-2013, 11:53 AM | #42 |
Quarry Creeper Join Date: Jun 2012 Location: Port Coquitlam, BC
I shipped the combo in to tekin for troubleshooting. Just waiting on their results before reporting back. Hopefully it's a easy fix...
03-06-2013, 12:44 AM | #43 |
| Re: Tekin ROC412 knocking noise |
03-26-2013, 08:17 AM | #44 |
Quarry Creeper Join Date: Aug 2009 Location: Snohomish, WA
My roc is doing the exact same thing....! I thought it was normal as this is the first BL motor I've ever owned... I will try the things mentioned previously in this thread but if I cannot fix it, I will call tekin as the motor and esc (RS pro) is less than 3 weeks old... I have subscribed so I look forward to the results of your new combo. Excellent support so far Tekin! Sent from my iPad using Tapatalk HD |
03-26-2013, 11:04 AM | #45 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
It is an anomoly and doesn't affect performance or cause any damage at all. It is sort of a rare occurence, usually just barely moving the rig stops it.
04-11-2013, 02:08 PM | #46 |
Just an update... So while I was waiting on the return of the ESC/motor combo, I had switched paces and start working on my scaler build. I went out and got another RS Pro/ROC412 combo and proceed to wire it all up. gave it a good test run and it all worked out very well. I then started tuning it and at the same time, updated the ESC to the latest version. After doing so, I got the same issue, the motor would knock. I just left it as is for now and ignored it. Fast forward a few days to where got my new RSpro replacement (NIB), went ahead and soldered it all up and installed it back into my R1. Flashed it, and restored the settings. I took it out for about 5 mins, and again, the motor started knocking. So that's three ESCs in a row with the same issue. Anyways, I haven't decided on what to do now, I'll probably just live with it, or downgrade to 212 where it is not an issue. |
Tekin ROC412 knocking noise - Similar Threads | ||||
Gmade and Tekin, roc412 | cytogen | G-Made Crawlers | 0 | 01-25-2013 02:42 AM |
light knocking noise in my F250 | BigSki | 1:1 Full Size Vehicles | 6 | 11-08-2012 07:42 AM |
Tekin Motor - weird noise | Moabman799 | Electronics | 5 | 03-20-2012 07:24 AM |
