02-09-2013, 08:04 PM | #21 |
Newbie Join Date: Oct 2011 Location: Alberta, Canada
| Re: TEKIN FX-R vs CASTLE SV3
I have a SV3 and I did have an issue with it. With brushed motors, it is not smooth at all. I don't think it is a common problem, so I will buy more. I am waiting for them to be available at my supplier and I will order another one to try. The one I have works fine with a brushless motor, so I am sure I can find a use for it. Castle has sure done a nice WP job on this one. It is not a simple thin coating on the board like other so called WP ESC's. The entire board in molded in an epoxy or something like that. I can't see how water could get to it at all.
02-09-2013, 09:01 PM | #22 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
Huh...mine works quite well with the brushed motors throughout the power curve...I've used a 12t titan and 27t axial, 35t venom and a 40t Holmes hobbies motor on my sv3....haven't experienced the problems u guys r describing yet. That's on 2s though..I am waiting for my 3s packs..what r you running yours on?
02-09-2013, 09:46 PM | #23 |
Quarry Creeper Join Date: Feb 2013 Location: Coupeville, WA.
| Oops!!!
I am now in need of a new ESC. I week with the axial ae-1 and we got a little bit of snow yesterday....it caught fire. I am a noob and believe I made a dumb mistake. Anyways, I was looking into the SV3 and now am slightly worried about the smoothness with brushed motors (have the axial 27T). One of you has had problems and the other hasn't? Can anyone else weigh in on this? Also (noob question) do you need an external BEC with these or do they have the power to run future ad ons? Last question, it comes with a usb cable so I do not need a castle link, is this right? |
02-09-2013, 09:57 PM | #24 | |
| Re: Oops!!! Quote:
02-09-2013, 10:40 PM | #25 |
No cable huh? That means I would have to shell out some extra dough for the link...is there a free version of the software if I have a cable and windows?
02-09-2013, 10:48 PM | #26 |
The software is free. It doesn't just work with a cable though. The Castle Link is a chip that connects the USB cable to the ESC.
02-09-2013, 11:14 PM | #27 |
That is good to know. You are making me nervous with your other thread about the problems with your SV3. If you are ordering another, I suppose it says you still believe in the product. Do I need an external BEC or will it power my rig and future upgrades with no problems. I am running a stock SCX10 now, but may add winch/2 speed transmission/etc. in the future.
02-09-2013, 11:26 PM | #28 |
The problem that I have is only one. I do believe I got a bad one. Every manufacturer is going to have a few bad ones. The most important thing is how they offer support. Castle offered to check mine out if I sent it back. I won't send it back because it still works good with a brushless motor, so I have other uses for it. I did not even try mine without an external BEC. I just assumed I would need one with a high torque servo, winch, and a bunch of lights. |
02-10-2013, 01:21 AM | #29 |
I suppose I could just wait and upgrade to an external BEC after I need to. I am just trying to limit my initial cost to appease the wife. Also, after doing some more reading, it looks like I do not have to get a castle link after all. You can program the ESC using the transmitter (I can imagine it is more of a PIA, but cheaper for now). Sorry if I have hijacked this thread, it seems related though. |
02-10-2013, 10:29 AM | #30 | ||
| Re: TEKIN FX-R vs CASTLE SV3 Quote:
As to the Castle Link, the older Mamba Max just needed the link software & a USB cable. All the newer Castle ESC's (that I've seen) need the adapter/programming board as well as a USB cable. Yes, you do some programming of the ESC using the radio, it's just a bit "fussier" to do. | ||
02-10-2013, 08:26 PM | #31 |
So if I am looking for a castle link what do I need to buy? I see a castle creations castle link programming kit, but there is also a castle link quick connect. Do I only need the programming kit for the SV3? I am having to add this cost in to the purchase before I order so just trying to figure out my cost. I may have found a castle link (waiting for person to send me pics of what is included) for about half a new one. Anyways thanks for the help.
02-10-2013, 10:41 PM | #32 |
Rock Crawler Join Date: Sep 2012 Location: Roxborough, CO
The castle link quick connect is so that you can have your ESC buried and mounted away along the all the other bits and still be able to program it. Typically you need to unplug the esc from the rx in order to program it - the quick connect detects a programmer, and does the disconnect for you electronically - so it's not really needed, it is a convenience factor. The castle link is what does the actual programming interface with the PC. Hope that helps! |
04-15-2013, 08:05 AM | #33 | |
Newbie Join Date: Dec 2012 Location: casselberry
04-15-2013, 08:07 AM | #34 |
The sv3 is an awesome esc completely submerge them and they never ever loose power or connection all of us about 15 every sunday run them and we love em ,they are great and the price unbeatable the tekin does not like any kind of water what so ever so stay away from them if you like water
04-15-2013, 08:11 AM | #35 | |
04-15-2013, 10:28 AM | #36 |
RCC Addict Join Date: May 2011 Location: Utah County
I should probably put my input here now. I'm the OP. I've been using SV3's for a couple months now and i love them. Then only disadvantage I've found is they're bigger than the fxr. But that's fine. Sent from my SCH-I535 using Tapatalk 2 |
04-15-2013, 08:39 PM | #37 |
Pebble Pounder Join Date: Mar 2013 Location: Vancouver
Thanks for all this info I was looking at the SV3 to run brushed and living in canada west mm we see water |
08-27-2013, 06:24 PM | #38 | |
Pebble Pounder Join Date: Jun 2013 Location: Greenbrier
Are you still happy with your SV3? What motor are you running with it? | |
08-27-2013, 08:25 PM | #39 |
Quarry Creeper Join Date: Jul 2013 Location: Salem/Portland
Imo tekin all the way if u want to run brushless in the future buy a mmp or waterproof anything u buy my tekin runs on 3s under water all day
08-28-2013, 03:07 AM | #40 |
Rock Stacker Join Date: Sep 2009 Location: Midlands England
Hi Just reading this thread and about to buy a fxr combo 35t set.Now not sure does this castle sv3 have drag brakes as well it does not mention it on the modelsport web site.Is it ok in a crawler. Thanks Paul. |
TEKIN FX-R vs CASTLE SV3 - Similar Threads | ||||
In Stock Castle Creations 1/10 SV3 Sidewinder 12V ESC Waterproof | RPP Hobby | RPP Hobby | 11 | 05-03-2013 05:17 PM |
Castle Creations SV3!! | MiniMorris | Electronics | 12 | 02-28-2013 02:07 PM |
castle sv3 question | CRAWLERJOE | Electronics | 2 | 12-25-2012 09:28 PM |
Castle creations sv3 Waterproof | pajey | Electronics | 2 | 12-21-2012 07:19 PM |
