02-08-2013, 11:26 AM | #1 |
RCC Addict Join Date: Mar 2011 Location: easton
| clod electronics help!
ive gotten my clod to the point that i can drive it around! now what i need help with. for some reason when i try and move it only one axle is making it move, occasionally the other will decide to work as well. any ideas how to fix this? the electronics are: spektrum dx3c with losi mrx3000 rx 2 traxxas xl5 2 integy 55t lathe motors 2s 25c 4100 mah lipo Sent from my iPod touch using Tapatalk |
02-08-2013, 12:36 PM | #2 |
it also happens consistantly when trying to go forward. its fine in reverse. Sent from my iPod touch using Tapatalk |
02-08-2013, 07:25 PM | #3 |
| Re: clod electronics help!
Sounds like a combination of motor timing & clod stall. Set both motor timing to "0" and see what happens. We can go from there. Do both motors have similar runtime on them? |
02-08-2013, 08:35 PM | #4 | |
is there anyway to get rid of the clod stall? Sent from my iPod touch using Tapatalk | |
02-09-2013, 06:51 AM | #5 |
If the Clod is a MOA, then one motor spins "forward" and the other spins "backwards" so the truck works correctly. Most motors come with some timing in them. If you order from Br00d or Holmes & state they will be used in a MOA, then they will correctly set the timing & mark them as "front" & "rear". Since I'm assuming you just "ordered 2 motors", they are both timed the same way, thus one is advanced & one is retarded. If these are "sealed can motors", you really can't change the timing. As to "fixing" clod stall. Best way is dual ESC's & a radio that can do throttle mixing/proportional. A hacked GT3B can do this as can others. A "cheap fix" for a simple radio is to run different sized pinions front & rear. Not the best solution, but it helps some. |
02-10-2013, 06:59 PM | #6 |
ok ill probably pick up a 4pl in a few weeks to use for my crawlers i swaped out the dx3c for an am traxxas tq radio. ironically a cheap am radio isnt having as big of an issue. the only complaint is that occasionally when its in front of my home theater, there is some kind of interferance. im also listening to fm radio when this is happening. Sent from my iPod touch using Tapatalk |
clod electronics help! - Similar Threads | ||||
lowering the body and the electronics getting the electronics in a waterproof box | m1009cucv | Axial SCX-10 | 15 | 10-01-2011 07:45 PM |
Electronics for clod axle setup | NickRummy | Electronics | 4 | 11-11-2005 07:55 PM |
