03-04-2013, 11:22 PM | #1 |
RCC Addict Join Date: May 2011 Location: Utah County
| will i fry my ESC if.....
So I ran an FXR, CCBEC, 7955tg, and 3s lipo in my c2 rig for at least a year. I recently removed the FXR to switch to a different esc and noticed that on that particular ESC i forgot to remove the red wire form the plug to the RX. My question isn't really "will i fry my esc if i dont remove the red wire?" i just used that title to lure you in here. My question is: "Why did I never, EVER have any issues with my high torque servo, FXR, and 3s if I had the red wire plugged in the whole year i ran that rig?" more questions: With the red wire still plugged in, does that mean the internal FXR BEC was powering my servo the whole time? does that mean BOTH the IBEC and the EXBEC were powering the servo the whole time? If i weren't running a high end RX that whole time, would the combined IBEC and EXBEC power fried my RX? i'm perplexed. Hopefully some electronics experts can chime in |
03-05-2013, 01:44 AM | #2 | |
| Re: will i fry my ESC if..... Quote:
03-05-2013, 02:06 AM | #3 |
hmm interesting. does anybody know of a definitive thread about the lil red plug? I just wired up my FJ-Cruiser saturday with a new ESC/BEC and i'm tempted to leave the red plug in tact to see what happens. see if i get lucky twice? or if it's just a myth? I'm NO EXPERT with electronics, but I would guess that having BOTH red wires (ESC and BEC) in tact and plugged into the RX, that it would be fine. The RX will "pull," like you said, the power that it needs. Whether it be from the ESC or the BEC. I always compare electricity flow to water. With two red wires connected to the RX it's like having two pipes of water combining into one pipe. And the servo is at the end of the one pipe. The servo pulls water out, it doesn't care which of the two pipes the water came from because the two pipes have combined to one pipe. - i dont know whether that will make any sense, or even if it is correct.. but that's why my brain says! so i'm typing it! because that's what the internetz are for! |
03-05-2013, 06:18 AM | #4 |
I guess the first question is......what output voltage is the CC BEC set for? If it's the same as the internal ESC BEC, that may be why you have not had an issue thus far. Have you tried disconnecting the external BEC to see if the internal BEC still works?? [next time you turn it on...poof....they don't play together.....LOL] |
03-05-2013, 08:04 AM | #5 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Why chance it? I've popped both red and black off my ESC lead - just run the white for signal.
03-05-2013, 08:27 AM | #6 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I have done it both ways before, but often when I only run the signal wire to a receiver I will suffer interference/glitching issues. It doesn't happen all the time, but most of the time it does. | |
03-05-2013, 09:09 AM | #7 | ||
Wanting to 'press your luck' eh? Good news is, I think the absolute worst thing that could happen is you burn out a BEC, an ESC, a receiver and a servo. As long as you've got the money to cover those, go ahead and gamble on it. Who knows, you might get lucky again and it all works. Won't know until you try. (though my guess is you either pop the cap on your exBEC or your iBEC burns out and the rest of the ESC continues to work fine.) Quote:
It's been documented that it is entirely possible to get backfeed through a BEC (without a diode on the output). In this case, one BEC would 'run wide open', with power being produced going backwards through the other BEC and back to ground. Guess you'll have to get your FJ wired up like you think it should be, and post back in here with your results. | ||
03-05-2013, 11:19 AM | #8 | |
The bummer to all this is i can't check to see if the ibec is fried cuz i no longer have said fxr in my posession. I hope the internal bec isn't fried cuz i sold it probably a month ago as a 'perfectly working esc.' Because it was working perfectly. I havn't heard anything from the buyer so i can only assume it's still working fine. But if the ibec were fried in theory you could just always run a exbec and never have an issue, right? Sent from my SCH-I535 using Tapatalk 2 | |
03-05-2013, 09:09 PM | #9 | |
will i fry my ESC if..... - Similar Threads | ||||
Did my esc just fry? | Nimyad | Electronics | 7 | 02-06-2013 08:50 AM |
Did me esc fry? | derbinator | Axial Wraith | 15 | 06-09-2012 12:05 AM |
Did I fry my ESC? | semnmrc | Electronics | 13 | 04-01-2012 09:23 PM |
Did I just fry my LNC ESC? | shelljeep | Newbie General | 24 | 02-09-2010 10:46 PM |
Will a 3s lipo fry my xl-5 esc? | jbrentd | Non Crawler RC's | 4 | 08-20-2008 12:51 PM |
