03-27-2013, 02:26 PM | #21 | |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: Holmes Torquemaster, bad luck?
You are comparing completely different motors. A HH 27t, in any form is going to destroy an axial 27t in power output. You probably had it overgeared anyways, but by your own admission you don't really get on it much. Overgeared motors won't blow up if you are easy on them..... Being just off a tooth can be too much for some motors....and they will blow up. In racing (same principles apply here), we would see motors of the same type need different gearing just because motor A would be more RPMish than Motor B....scenarios of up to 11 teeth difference(64 pitch) were not unheard of. Even in 48 pitch, we would see 2-3 teeth in some cases. Long and the short of it, the motor was overgeared. While there may of been binding or what, all that would do is speed up the fate that awaited the motor. Later EddieO Quote:
03-27-2013, 02:48 PM | #22 |
Pebble Pounder Join Date: Nov 2012 Location: on the edge!
bigstu: I get it I need different gears It is all about ratios. Question: I burned up my motor because the gearing is to high and it is to much work for the motor to move the rig? So if I get my ratio say closer to 5:1 and run it wide open that would not be as hard on it? Is this correct? Where do I go to get gears? Never mind I can find lower pinion gear. I really am trying and everyone is helping, "Thank you" Last edited by 04zrx; 03-27-2013 at 03:00 PM. |
03-27-2013, 03:07 PM | #23 |
I use Tower Hobbies for a lot of "generic stuff" since I'm a member and get shipping deals. I try to deal with my LHS as much as possible. There is a "general sweet spot" in motor gearing for most rigs, seems like ~5:1 in crawlers is good. It does NOT matter the gear pitch, just the ratio. Too tight a pinion/spur gear mesh can overload a motor (usually a short life) Too much binding in the drivetrain can overload a motor (usually a short life) I agree with Eddie & John, I used to race "spec class" 12th & 10th pan cars. The motors were all epoxy sealed motors (no comm cutting, no timing adjustments.....welllll....not "really"). First thing we did was to break them in and run them on our dyno. Some were "torque motors" others were "rev motors". We used them suited to the course (oval VS. road course) and adjusted gearing to match. Keep in mind, we STILL had issues with making the race time.....frikkin kids today have it wayyyyy easier...... A good set-up meant we did well in the race, then the NiCD/NiMH pack dumped on the "victory lap". |
03-27-2013, 03:14 PM | #24 |
ok I have 12,13,14,15and 16t pinions coming so I can experiment. I'm learning ....... It was much easier to get those pinion gears than attempt to find larger spur gears. Question: How should I set the mesh ? I put a piece of paper between the two...dunno if that is correct. There is no binding in the drivetrain. Last edited by 04zrx; 03-27-2013 at 03:20 PM. |
03-27-2013, 03:20 PM | #25 | |
| Re: Holmes Torquemaster, bad luck? Quote:
I will not even try to guess the 48p pinion ranges I have for carpet & dirt cars. I usually have 2 or 3 of everything........sigh.... The "smaller the pitch" the more likely it can deal with crap in the gear mesh, the "larger the pitch", the finer you can gear overall.... | |
03-27-2013, 03:30 PM | #26 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
| Re: Holmes Torquemaster, bad luck? You're welcome. I apologize if you thought I was fired up. Just trying to make it simple to understand, which can be a challenge some times. Too many thoughts in my head. LOL... With the 87/18 gearing combo, you were at 4.8333 to 1 gear ratio. That is pretty close to 5 to 1. If you want to run a lower turn motor, you're going to have to go much higher. My advice, and again this is what I would do. I'd get a 90-93 tooth Spur gear and 3 pinions 12, 14, and Maybe a 16 tooth. 93/12 = 7.75 90/12 = 7.50 93/14 = 6.64 90/14 = 6.43 93/16 = 5.81 90/16 = 5.63 93/18 = 5.17 90/18 = 5.00 - You already have a 18t pinion.. You can see that with these combos, you get a gear ratio that is right around a 7.5, then a combo that is about a 6.5, then a combo that is a 5.5, then a combo that is a 5.0. You know the something close to 5.0 = ... So I wouldn't go any lower than that. Go to Tower Hobbies. Here is what you need. One of these: TowerHobbies.com | Robinson Racing Super Spur Gear 48P 90T AX10 Or MY choice, one of these: TowerHobbies.com | Robinson Racing Super Spur Gear 48P 93T AX10 One of these: TowerHobbies.com | Robinson Racing Pinion Gear 48P 12T One of these: TowerHobbies.com | Robinson Racing Pinion Gear 48P 14T and One of These: TowerHobbies.com | Robinson Racing Pinion Gear 48P 16T If you buy one of all of those it is $25.23 + shipping of your choice. |
03-27-2013, 03:43 PM | #27 | |
The way I set all my pinions is by feel. Just a little separation of the teeth. It's usually just enough so when you hold the pinion you can hear that spur thump back and forth, or see one move on the other, VERY slightly. Here is a good one: HorizonHobby.com How-To: Understanding RC Gearing - YouTube Also, check to make sure you don't have a drive shaft, or anythign else binding in the drive train. Pull the pinion off the motor and roll the tires, etc. If it stops right away or you can feel resistance, there is a problem. And don't be afraid to push the spur gear with your finger and see if there is resistance there. Again, if any, there is a problem. I smoked a Brood motor by not noticing that I had a driveshaft ourdrive that was rubbing on full extension. As soon as the axle flexed out, it bound up the drive train. Smoked the motor in less than 5 minutes. Something as simple as a trans housing being too tight or a set screw that loosened up can cause drag and smoke a motor too.. | |
03-27-2013, 03:56 PM | #28 |
I set my gear mesh by feel. I rock the spur back and forth and make sure I can feel just a little back and forth movement on 3 different locations on the spur and tighten the motor down then check it again to be sure.
03-27-2013, 03:58 PM | #29 | |
Keep in mind, not all spur or pinions are "concentric", thus to really check gear mesh, you need to spin the gears and check in multiple spots. Set "almost "0"" gear lash in the tight spots so you don't strip gears in the looser spots. | |
03-27-2013, 04:16 PM | #30 |
Spur gears ordered! Thanks for doing all the leg work for me.
03-27-2013, 06:57 PM | #31 | |
Rock Stacker Join Date: Apr 2010 Location: Santa Fe
03-29-2013, 05:00 AM | #32 |
Update: John sent me an e mail and is offering to exchange my burnt motor for a brushless motor. I accepted the offer and will be getting a 13.5 BL Trail master. John feels that I won't be happy with brushed and this will happen again if I stay brushed. I'll take his advice and go brushless. In my book that is standing behind your product! "Thank you John Holmes" I will continue to use Holmes Hobbies for my future motor purchases.
Holmes Torquemaster, bad luck? - Similar Threads | ||||
If it weren't for bad LUCK I wouldn't have any luck at all | redrokin00XJ | Redcat Crawlers | 10 | 02-06-2011 11:18 AM |
You think you have bad luck? | biggin69 | Chit Chat | 1 | 03-16-2010 03:17 PM |
Bad luck or stupidity? | Rockcrawler | Chit Chat | 23 | 03-05-2010 02:09 PM |
dang. bad luck friday. | JohnRobHolmes | Chit Chat | 9 | 11-26-2005 11:03 PM |
Bad Luck | ManiacMagoo | Chit Chat | 8 | 08-03-2005 08:11 AM |
