04-03-2013, 03:55 PM | #1 |
Quarry Creeper Join Date: May 2005 Location: edmonton
| mumba max pro, not always hitting reverse?
see post 3
04-03-2013, 04:02 PM | #2 |
Newbie Join Date: Jun 2009 Location: San Diego
| Re: truck faster in reverse than forward?
Sounds like you just need to reprogram you esc?
04-03-2013, 04:04 PM | #3 |
ya i was thinking this but i can't find that in the manual. i should state that i'm using AR60 axles now and was using SXC10 before. i think i may be onto something? Last edited by TRAV; 04-03-2013 at 04:13 PM. |
04-03-2013, 04:12 PM | #4 |
| Re: truck faster in reverse than forward? http://www.castlecreations.com/suppo...er%20Guide.pdf I'm on an iPad but that should be very similar to what your esc should do. Try going threw the steps and seeing what it does. |
04-03-2013, 04:45 PM | #5 |
so I flipped the gears in the diff. and whola is drive forward faster now. new problem it dosent always go into reverse now. only like every 5th time or so. any suggestions |
04-03-2013, 04:56 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Canada
| Re: mumba max pro, not always hitting reverse?
Does a double tap put it into reverse? sounds like programming, as mentioned before. It sounds like it's set up in reverse trigger to brake mode. like an XL-5
04-03-2013, 05:40 PM | #7 |
not always. sometime i can flick to to or 3 times before it goes in, some times it never reve. |
04-03-2013, 07:30 PM | #8 |
It's programming.. I remember my slash use to do a bunch of random stuff when I didn't program it and I just wanted to run it. Just try setting it up
04-03-2013, 07:52 PM | #9 |
It's a pain in the butt to program without a castle link. Try to follow the instructions as best you can, but it's a lot of beeping and swearing.
04-03-2013, 08:50 PM | #10 |
or so after running through the programming. what a pain. turns out its my TX. the throttle was not always returning to neutral. when I wiggled it the yellow light comes on in the esc. |
mumba max pro, not always hitting reverse? - Similar Threads | ||||
faster in reverse than forward | dirtymike | Electronics | 9 | 11-09-2012 07:38 PM |
Fast Forward, Faster Reverse | dAng! XJ | Axial Wraith | 17 | 01-13-2012 08:20 PM |
reverse is faster than forward | wassaakk | Newbie General | 6 | 07-01-2010 07:22 PM |
WK runs faster in Reverse than Forward? HUH?! | JavelinSST390 | HPI Wheely King | 7 | 08-31-2007 07:14 AM |
