04-11-2013, 04:22 PM | #1 |
Rock Stacker Join Date: Dec 2012 Location: Guam
| reciever question
I have used the search button but couldn't find what I was looking for. My question I wired up my new novak eiger with 35t motor. I have check the wiring over and over. My issue is when I plug the esc plug into reciever the throttle will not work. When I plug it into the servo port it works fine with the steering wheel. Does this mean my reciever is messed up. I wouldn't mind an excuse to buy a new one just want to make sure. |
04-11-2013, 04:40 PM | #2 |
| Re: reciever question
Did you calibrate the ESC to the RX in the correct RX port???? It's the 1st thing to do. Most ESC calibrations are: Throttle trims (including subtrims) to "0" Throttle EPA's to "100%" Futaba radios need to have the throttle channel set to "reverse". |
04-11-2013, 04:51 PM | #3 |
It won't let me calibrate it in the first place, I know the wiring is correct, just won't calibrate rate I have tried four times and have followed the instructions
04-11-2013, 06:34 PM | #4 |
| Re: reciever question |
04-11-2013, 06:44 PM | #5 |
The red light stays solid which has you check the wiring. I plugged the servo inyi the throttle it doesn't work. Throttle in the servo works
04-11-2013, 07:13 PM | #6 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
maybe thats the rx causing the problem. do you have another rx to try with
04-11-2013, 08:11 PM | #7 |
I don't have another reciever or I would test it. I was able to program the esc with the throttle wire in the steering slot and the servo was plugged into the throttle slot. The esc programmed so my throttle was controlled by my steering wheel. And the steering didn't work. Makes me think it is the throttle port on the reciever. Gonna take it to the hobby shop tommorow and use one of his recievers to test it out. Thanks for the help guys. I appreciate it.
04-12-2013, 11:06 AM | #8 | |
| Re: reciever question Quote:
04-12-2013, 03:24 PM | #9 |
Bought a new futaba tx and rx. Thanks guys
04-12-2013, 04:44 PM | #10 |
| Re: receiver question |
04-12-2013, 07:23 PM | #11 |
Just a cheap basic t3prka. I got something basic, something more advanced will be on the upcoming tow rig and trailer for the f350 truggy
reciever question - Similar Threads | ||||
reciever question | honcho1.9 | Electronics | 6 | 02-04-2011 12:36 PM |
Reciever question | c0mf0rt | Newbie General | 3 | 11-28-2010 07:04 PM |
reciever question | dkchance74 | Electronics | 4 | 09-22-2009 10:19 PM |
Reciever question | WyldWeazel | Newbie General | 8 | 07-18-2008 08:19 PM |
