04-11-2013, 07:34 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Omaha, Nebraska
| ae2 esc problem
Ok I hooked my battery up to my esc and turn everything on like normal but this time the led on the esc is blinking green and red at the same time and constantly beeps. My question is whats wrong and how do I fix it? Thanks in advance, Kenneth |
04-12-2013, 11:04 AM | #2 |
| Re: ae2 esc problem
Hmmm....that color combo does not come up here.... Castle Creations | FAQ: 1/10th Scale Products (bottom of the page). Try plugging the ESC into the steering channel and see what happens. Have you done anything to the electronics recently? Was this working before? Have you tried to recalibrate the ESC to the RX? Does the steering still work? If not, maybe you need to bind the RX to the TX. Is the rig battery charged? Are the TX batteries good? |
04-12-2013, 11:45 AM | #3 |
| Re: ae2 esc problem
Will try it when I get home, no, yes, how do I do that?, steering works, rig and tx batteries charged.
04-12-2013, 11:53 AM | #4 |
| Re: ae2 esc problem
Recalibrate: 1-TX throttle trims to "0" (including sub trims if you have them) 2-Throttle EPA's to 100% 3-Calibrate How to: http://www.castlecreations.com/suppo...s_ed_guide.pdf What radio? PS, good replies, helps out troubleshooting. |
04-12-2013, 11:58 AM | #5 |
| Re: ae2 esc problem
Will try it after work, futaba 3pl, thanks
ae2 esc problem - Similar Threads | ||||
ae2 esc ? | chazekxt | Electronics | 13 | 06-24-2012 10:03 PM |
AE2 ESC issues | chopan84 | Electronics | 10 | 09-26-2011 11:39 AM |
ae2 esc | dracbec | Axial AX-10 Scorpion | 0 | 04-17-2011 11:40 AM |
