Thread: Winch control w/ Flysky GT3C ?
Old 03-26-2013, 10:21 PM   #1
Default Winch control w/ Flysky GT3C ?
Can work?
Or Tx needs to be modded?
Or only option is the HeyOK controller?
Tanx
Statik is offline   Reply With Quote
Old 03-27-2013, 06:28 AM   #2
Default Re: Winch control w/ Flysky GT3C ?
heyok controller for a 2pos switch
losikids hack kit gives you 3 pos channels, cheaper in the long run if you plan to have more than one rig.
if your going to buy something to run the winch, and going to have more than one rig, id get the Hack kit. you have to get a controller for each rig if you go with the HeyOK control. nothing wrong with the HeyOK control.
biggest factor for me was that i have 4 rigs with winches, i could have bought 4 2pos controls, or just 1 hack kit for my gt3b, i got another rig planed,so id need one more controller.
you can run 60 some models off the hacked radio
or. go in to 3rd channel EPA and turn it all the way down one direction,left or right, it dont matter, then use servo reverse on ch 3 to control the direction the winch goes,ran mine like this for a few months, works ok, but you can hit the button running and burn the winch up if its set to retract,(did it to a rc4wd winch) or knot the line up if set to spool out(done it many times, pain to untangle)
stanmondz is offline   Reply With Quote
Old 03-27-2013, 06:58 AM   #3
Location: Turn the mayflower around.. it will never work
Hack your gtc3...... Get heyok controller...... Done.
JokersWild is offline   Reply With Quote
Old 03-27-2013, 09:29 AM   #4
why both? what does this get you?
Docwolf is offline   Reply With Quote
Old 03-27-2013, 09:39 AM   #5
SuperShafty.com
The controller keeps the servo from drifting. It's a good thing to get the hey ok controller if you run a servo winch
mjderstine is offline   Reply With Quote
Old 03-27-2013, 09:40 AM   #6
Originally Posted by mjderstine View Post
The controller keeps the servo from free spooling. It's a good thing.
I have a 3racing winch and controller that I have never hooked up, does that controller do the same?
Old 03-27-2013, 09:46 AM   #7
Tzi
A fully programmable radio.. any button = any function
As an example, I use the steering trim and throttle trim buttons on the top of the radio to control my front and rear winches, and also have the ch3 trim on the handle set up for the front winch (great for single handed use when the other hand is holding the winch line)
The ch3 button on the handle being an on/off type is great for switching lights on and off.
Regardless, an aftermarket winch controller is a MUST if you have one of the cheap winches.
3racing winch comes with a controller that will stop working the first time it sees any decent load, and the rc4wd controller that comes with the winch cant hold still and will either spool in or out very slowly.
They all have their flaws.
Tzi is offline   Reply With Quote
Old 04-12-2013, 10:25 PM   #8
Can the ch3 button turn lights off/on with out being Hacked?
Cheers Red
Red04VXE is offline   Reply With Quote
Old 04-13-2013, 06:05 AM   #9
Cheers Red
Yes. You only need a two position channel to operate lights.
This will require a lighting controller to be plugged into the receiver.
Click the link in my sig if you want to see the lighting controllers I make.
heyok is offline   Reply With Quote
Old 04-13-2013, 10:23 PM   #10
I wish I had before I brought this http://www.axialracing.com/products/ax24257 with the kit. They are on all the time.
Cheers Red
Old 04-13-2013, 11:05 PM   #11
I wish I had before I brought this Axial Racing - Simple LED Controller w/LED lights (4 white and 2 red) with the kit. They are on all the time.
Cheers Red
I have two of those plugged into HeyOK's dual circuit controller so I can run either of them from the Tx.
KJ10 is offline   Reply With Quote
Old 04-14-2013, 11:37 AM   #12
I have the gt3c hacked, works great with my servo winch but without controler i get drift if i dont set my trim on startup. Getting a controler for mine asap.
buggynutt is offline   Reply With Quote
Old 04-14-2013, 07:18 PM   #13
Hacked gets you huge benifits........ Search out on gt3b thread and you will get it. Basically will do more thany anything you can think of.
Controller will keep from drifting and will actually hold when stopped.
Old 04-14-2013, 07:31 PM   #14
Why wouldn't they work on there own? Just 1 I mean.
Cheers Red
Old 04-14-2013, 07:45 PM   #15
They do work on their own but there's no way built in to turn them off. I run a separate controller for a switch, basically.
Winch control w/ Flysky GT3C ? - Similar Threads
Flysky GT3B and servo winch Deerhurst Electronics 6 03-14-2018 04:18 PM
Flysky GT3C: First Look losikid Electronics 104 12-22-2013 12:25 PM
winch control djmikeb Electronics 4 03-07-2011 08:25 PM
