Thread: When to Use CC BEC vs. Glitch Buster?
Old 05-11-2013, 11:30 AM   #1
Default When to Use CC BEC vs. Glitch Buster?
So when it comes to electronics it's a freaking miracle that I even know half the things I do know lol.
I understand the CC BEC and how it works and also the benefit of program-ability for higher end servos beyond 6.0V.
Now and then I use Novak's Glitch Buster on my less power hungry servos like my Savox 1251MG which I run on my SC10B.
So when do I use which Novak Glitch buster versus CC BEC?
I also feel more comfortable that the CC BEC splices into ESC.
Total noob question lol. I apologize.
alexchen86 is offline   Reply With Quote
Old 05-11-2013, 11:35 AM   #2
Default Re: When to Use CC BEC vs. Glitch Buster?
CC bec, always.
Calderwood is offline   Reply With Quote
Old 05-11-2013, 12:47 PM   #3
Originally Posted by nigels_world View Post
CC bec, always.
+1.
Glitch busters are a "band-aid" (in my eyes....FWIW) vs. an external BEC as a fix.
If you're over ~200inoz servo output, get an external BEC and be fine.
A "glitch buster" can help "fix" certain issues, but the better fix is to get:
Better batteries
Better connectors
Better solder joints
Charlie-III is offline   Reply With Quote
Old 05-11-2013, 03:00 PM   #4
Like the rest of Novaks products, if you need to burn something down, or to fill up your trash can, a glitch buster is great. In all other situations, the castle BEC is it. I run one in every single RC anything I have.
The Violator is offline   Reply With Quote
Old 05-11-2013, 04:29 PM   #5
X2 on CCBEC... It's inexpensive; just go ahead and do it right the first time!
1r3land is offline   Reply With Quote
Old 05-11-2013, 08:44 PM   #6
Wow...I always thought CC BEC's were overkill for a little metal gear servo for a lightweight 1/10 2wd buggy. Always figured we wanted CC BEC's on our rigs since that way we get the most out of our servos at all times.
Old 05-12-2013, 09:39 AM   #7
No mater what your using it in it will take some load away from your ESC and help it run cooler. Thus extending its life. I use them in everything to!
TrickyRicky is offline   Reply With Quote
Old 05-12-2013, 01:32 PM   #8
With the buggy you would still want the extra speed that higher voltage would provide even if torque isn't such a concern. 7+ volts really wakes a servo up.
When to Use CC BEC vs. Glitch Buster? - Similar Threads
Glitch Buster Opto-Isolator CoolRC Electronics 7 07-28-2010 10:58 AM
Novak Glitch Buster Capacitor nickhpiracing Electronics 4 06-17-2009 06:39 AM
novak glitch buster ohmyCLOD! Electronics 1 12-24-2008 11:32 AM
CC BEC causing glitch Neil426 Electronics 9 12-07-2008 11:09 AM
