Thread: Got a question for you about lipos
Old 05-26-2013, 08:44 PM   #1
Default Got a question for you about lipos
I bought a used Arrma Vortex, and it has a built in battery tray in the bottom of rc, its needs a recommended battery sized 138mm x 47mm x 25mm is this a common size, and if you get one smaller the recommended size does it move around, and damage the battery, if that is the case, would it be better to buy a hard case lipo the the recommended size to avoid damage to battery correct.
kgb424 is offline   Reply With Quote
Old 05-26-2013, 10:42 PM   #2
Default Re: Got a question for you about lipos
Not familiar with that setup but you can use sticky back velcro (hook and loop) to stick a battery in place. I like the hook side on the tray and the loop side on the battery.
Amoured batteries are a good idea but since crawlers are generally slow they are not really required. Lipos come in lots of different sizes which is part of their advantage.
I have a couple of amoured lipos and they are 139*47*24
Sky Lipo Battery 2000mAh 20C 2 cells
so you should be able to find the size you need.
AutoCrawler is offline   Reply With Quote
Got a question for you about lipos - Similar Threads
Question about charging lipos manalow88 Electronics 2 06-22-2012 02:47 AM
Question about Traxxas Lipos Landcruiser 110 Electronics 17 01-23-2012 05:32 PM
Quick question on lipos Veilside159 Electronics 4 12-21-2009 02:44 PM
Do CKRC Lipos Suck? ~ Discharge & Burst Rate Question MtnBkr Electronics 9 06-08-2009 08:33 AM
