05-18-2013, 07:54 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: SW Iowa
| Airtronics MXS bind issue - no throttle
I went through the bind process, finally got it to bind to steering. Kept messing with it and the throttle finally kicked in. Took it out to the field, no throttle. Messed and messed with it, the esc lights change when I hit reverse on the transmitter, but otherwise nothing happens. Steering works fine. |
05-19-2013, 01:21 AM | #2 |
| Re: Airtronics MXS bind issue - no throttle
Tried it with a different radio and it was doing the same thing, so I reset the esc and everything is working now. Can't seem to figure out why I got it to work, then it just stopped again. Even worked once with the different radio setup, then quit again. Appears that the esc reset fixed it though.
05-19-2013, 05:58 AM | #3 |
Sounds like you skipped the ESC calibration step. Binding is for the TX & RX. Calibration is the ESC to the RX. If the ESC is not calibrated, the steering will work, but throttle is iffy. |
Airtronics MXS bind issue - no throttle - Similar Threads | ||||
Ax-10 bind issue... | Team_Jason_RC | Axial AX-10 Scorpion | 6 | 06-28-2012 06:52 PM |
4PL throttle issue | rcscaler | Electronics | 11 | 01-09-2012 05:46 AM |
HR Dig bind issue need help | pontiacfreak | Newbie General | 0 | 01-23-2010 01:57 PM |
Can I Bind a Spektrum Rx to an Airtronics Tx | 70duncan | Electronics | 2 | 06-23-2009 10:21 PM |
Throttle issue | Littledeuce | Electronics | 6 | 01-12-2008 11:28 AM |
