05-23-2013, 08:16 PM | #1 |
Quarry Creeper Join Date: Mar 2012 Location: Montreal
| putting a hook in a 4PL
Hi, not sure if this goes in the electronic section but hey... I would like to put a hook on my 4PL so that I can use a neckstrap (also as an added security to prevent it from falling). As anyone got a "best place to put the hook" suggestion, I tried to look in the forum and couldn't find answer. Thanks! |
05-23-2013, 08:34 PM | #2 |
Rock Stacker Join Date: Feb 2009 Location: California
| Re: putting a hook in a 4PL
Take a look at these it may give you some ideas Post #2019 Futaba 4PL Setup, Tips, Tricks & Help 30 Second 4PL lanyard install |
05-23-2013, 08:40 PM | #3 |
Thank you very much! Time to drill things! |
05-23-2013, 08:59 PM | #4 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
The holes for the screws that keep the plastic sides together will accept a 1/4-20 nylon bolt and hold a decent amount of torque on it. You must shorten the nylon bolt to fit the particular hole chosen. I added a strap (approx 1"x6" webbing) parallel to the pistol grip that fits over the back of my hand for extra grip stability. The shallow screw holes don't grip the bolt as well and I ended up tapping both holes for the bolts. Threads are very shallow but increase the holding power. If I knew how, I'd post a couple of pics.
05-23-2013, 09:25 PM | #5 |
Used a 14ag noodle wire, little solder, shrink wrap inside the casing... perfect! Thanks a lot! |
05-23-2013, 09:28 PM | #6 | |
| Re: putting a hook in a 4PL Quote:
Going to a friendly comp this saturday, river side, didn't want to worry seeing my Tx falling in the water | |
putting a hook in a 4PL - Similar Threads | ||||
Need some help putting my Fj 40 together | Mark11 | Maryland | 4 | 07-22-2010 12:19 AM |
Has anyone tried putting different motors in yet? | chambiec1 | General Crawlers | 15 | 11-06-2005 06:45 PM |
