05-28-2013, 01:39 AM | #21 |
Rock Stacker Join Date: May 2012 Location: San Jacinto
OK so bec settings are good where they are. All the connections are soldered then heat shrinked. I don't have a volt meter.... I picked up a hitec 7955 so I'm going to grab a new bec and wire that up. Pull this one dismantle it and redo everything... replace all my battery leads as well. Is deans the way to go or should i go another route? Thanks everyone you're all great!! :thumbup: Sent from my Nexus 4 using Xparent Green Tapatalk 2 |
05-28-2013, 02:43 AM | #22 |
| Re: MoA Misadventures
I use Anderson PowerPoles/Sermos but they're a little larger, Tower Hobbies has them. Most use Deans connectors, there are the XT's and some other bullet connectors, or Traxxas. Tower has Deans as well. |
05-28-2013, 05:30 AM | #23 |
| Re: MoA Misadventures APPs are larger, heavier and handle less current. Deans are definItely the better choice. I used APPs back in my carpet racing days before deans connectors got popular.
05-28-2013, 05:46 AM | #24 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
Propably a silly question, but have you cheched for binding in the steering setup?
05-28-2013, 07:03 AM | #25 |
Steering seems free enough.... But haven't done anything other than move wheels side to side by hand..... Sent from my Nexus 4 using Xparent Green Tapatalk 2 |
05-28-2013, 09:38 AM | #26 |
Have you done this ^^^ with everything bolted up, as in ready to go but powered off? Reason I'm asking is that there might be binding between the servo horn/drag link, or draglink/steering arm.
05-28-2013, 10:42 AM | #27 |
Yeah , as it sits no power moved the front wheels left to right....... Sent from my Nexus 4 using Xparent Green Tapatalk 2 |
MoA Misadventures - Similar Threads | ||||
Mk42 Moa or bully Moa... Which is a better choice? | Oregon crawler | Newbie General | 3 | 08-04-2011 01:26 PM |
