06-16-2014, 04:16 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| anyway to make a AX2 or a sidewinder handle 4s?
like it says.. thanks
06-16-2014, 08:52 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: anyway to make a AX2 or a sidewinder handle 4s?
No. the voltage is way too high.
06-16-2014, 09:31 PM | #3 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
Depends on which sidewinder you have. I've read that the sv1 handled 4s with an external BEC. Not the Sv2.. From what I've read anyways. I've yet to try it on my SV1. I'm not sure about the ax2 |
06-17-2014, 06:22 AM | #4 |
SV1? original sidewinder? have a bunch of those
06-17-2014, 08:12 AM | #5 |
Good luck. You're most likely to thermal the esc. I have a on a fxr with bigger cap and 4s. What motor and gearing? |
06-17-2014, 10:01 AM | #6 |
stock gearing HH 35 motor
06-17-2014, 10:56 AM | #7 |
| Re: anyway to make a AX2 or a sidewinder handle 4s? |
06-17-2014, 11:22 AM | #8 |
My sidewinder SCT has 12v LVC. As do most sidewinders if I understand correctly. This is my only sidewinder I can test. I hooked up a 4s and it beeps 4 times does the normal chimes but no motor function. That being said, I didn't expect it to work. Supposedly running firmware 1.24 will work for 4s. Which is only available on the older sidewinders. Hope this helps. I was curious myself so I dug into it. If I get my hands on my other sidewinder sometime soon, which is an sv1. I'll update. |
06-17-2014, 02:47 PM | #9 |
87 spur and 20 pinion. pretty sure thats what it came with
06-17-2014, 03:15 PM | #10 |
If you end up trying this let us know! Also, I would really gear that down. I'd try a 10t pinion.
06-17-2014, 03:44 PM | #11 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
That's just craziness if you ask me..4s is wayyyy to much. The voltage is 14.8v obviously and I doubt it would work, why not buy an esc that CAN handle a 4s....
06-19-2014, 12:26 PM | #12 |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
| Re: anyway to make a AX2 or a sidewinder handle 4s? What he said. Why are you running a 35T brushed motor? It makes no sense at that voltage. Go waterproof brushless. You can a cheap set up for like 60-80 bucks. Ebay is your friend. I jut paid a little more than I would have liked, but got a 1415 castle 4 pole 550 can 2400KV motor for 60 bucks. I have a 4370 KV I got for 20 that's brushless. Buy them used, you get a 50% price discount which means even if 1 of ever 2 you buy is junk you end up even.
06-19-2014, 02:03 PM | #13 | |
| Re: anyway to make a AX2 or a sidewinder handle 4s? Quote:
I would suggest senored brushless system if you go that route. Non senored going to suck if you do any little of crawling. | |
06-19-2014, 10:27 PM | #14 |
06-21-2014, 05:35 PM | #15 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
I ran my custom HH resin waterproofed sidewinder v1 with external cc-bec on 4s at one comp without even thinking... Still works to this day Not saying its right... but sometimes ignorance is bliss ;) |
06-21-2014, 05:40 PM | #16 |
| Re: anyway to make a AX2 or a sidewinder handle 4s? I know on the Sidewinder first generation which I ran on my AX10 shafty comp rig years back you could roll back to the original firmware release and it did allow me to run 4s. I wouldn't recommend doing it for extended periods of time, but it is doable. The AX2 I am not familiar with though. Good luck and definitely watch your temperatures! |
07-05-2014, 06:26 PM | #17 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
Ive also ran my original sidewinder on 4S with the right firmware settings. I forget the gearing but it was a brood apocalypse kaos motor with a summit trans on 4s for comps and 3s otherwise. Worked well for me without any issues. There is a thread about the original sidewinder settings or something that has many others posting about success on 4S Sent from my SM-N900T using Tapatalk |
07-05-2014, 07:28 PM | #18 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
4s is where you want to be! Either trailing or comping, you just can't beat it...plus it's easier on your electronics (keeps amp draw down).
anyway to make a AX2 or a sidewinder handle 4s? - Similar Threads | ||||
ax2 and ..... | mcsgt98 | Axial Wraith | 10 | 06-05-2014 06:05 AM |
AX2 Tranny | Drking | Axial SCX-10 | 0 | 07-24-2013 02:12 AM |
Ax2 ? | Mr Bill | Axial AX-10 Scorpion | 8 | 04-17-2011 11:28 PM |
Will a sidewinder handle 4S lipo? | NickRummy | Electronics | 4 | 10-14-2008 04:59 PM |
