07-05-2013, 09:35 PM | #1 |
Rock Crawler Join Date: Aug 2010 Location: Esko
| Led wiring question
So i just put 2 led kits on my honcho up on top of the rollcage. They are the stock led lights from a honcho. So right now I have the stock lights that came on the truck (bumper and tail lights) and the 4 new ones [IMG][/IMG]on top. I just unplugged the tail lights from the 2 led controllers and I was wondering if I need to use both of the new led controllers or will it be OK if I just plug the 4 new lights in one led controller and then use a y harness to connect them to the same receiver input as the stock tail and bumper lights. Thanks
07-05-2013, 10:11 PM | #2 |
Quarry Creeper Join Date: Jun 2013 Location: Escondido, San Diego, CA
| Re: Led wiring question
The tail lights on the simple LED controller aren't meant to be changed to 4 white LEDs.. They won't be as bright as the headlight ones, try it. Since they aren't as bright, i would personally use both controllers and use a Y-harness
07-05-2013, 10:52 PM | #3 |
Rock Stacker Join Date: Mar 2012 Location: SoCal
Wait a minute, does that mean the two outputs on the Axial simple led controller is suppose to output different voltages? I actually having problems with mine. The headlights n driving lights (4 white) are working properly, but the 2 red rears are not working. What voltage readings should I be seeing at each output?
07-05-2013, 11:04 PM | #4 |
| OK I'll try it and see. If it doesn't work I'll use both. Just wanted to make sure it wouldn't hurt anything.
07-05-2013, 11:23 PM | #5 |
I am not sure of output voltages, I don't have a volt meter here with me, but my tail light led is coming off the controller on the same side as the power cable to the battery.. I haven't tried switching mine but I read on other threads a lot of people saying they output different voltages, because the 2 red LEDs need much less voltage (apparently red needs less voltage than white) When I get a chance I will try switching mine, I am about to waterproof the controller so I will be messing with it shortly |
07-05-2013, 11:29 PM | #6 |
I just tried it, when i plugged them in opposite, the tail lights worked, but the headlights didn't work anymore. so you'll probably need both controllers to make both sets of headlights work. |
07-05-2013, 11:37 PM | #7 |
07-07-2013, 01:30 PM | #8 |
One more question. I'm basically using 3 complete led kits from a honcho. Can I splice them all together and just use one led controller or do I need to use all 3 controllers? Thanks.
Led wiring question - Similar Threads | ||||
Quick LED wiring question | jeepscx10 | Electronics | 1 | 03-22-2013 03:18 AM |
led wiring questions | poomwah | Electronics | 24 | 03-02-2013 08:56 AM |
led wiring ? | yoda316 | General Scale Talk | 14 | 01-09-2011 08:09 PM |
LED wiring info | Nate08 | Electronics | 0 | 06-03-2009 05:39 PM |
LED wiring questions? | JavelinSST390 | Electronics | 3 | 11-11-2007 11:41 PM |
