Thread: What do you do when a Hitec 7980 and Castle BEC Pro aren't enough?
Old 05-25-2013, 12:54 PM   #1
Default What do you do when a Hitec 7980 and Castle BEC Pro aren't enough?
As title really bought the best gear I could find, thinking it would do the job with ease on my big scale crawler, but it stalls out with ease. Need and even stronger steering setup.
Anyone got any ideas? I'm totally stumped
Thanks.
simon170 is offline   Reply With Quote
Old 05-25-2013, 01:13 PM   #2
Default Re: What do you do when a Hitec 7980 and Castle BEC Pro aren't enough?
What is the CC BEC set to?? If stock, it's under voltage for the 7980. Get a Castle Link & up the voltage.
Why do you say, "It's not enough"????
Charlie-III is offline   Reply With Quote
Old 05-25-2013, 01:35 PM   #3
1/4 scale servo on a 3s.
DRTMI is offline   Reply With Quote
Old 05-25-2013, 01:55 PM   #4
Maybe?
Calderwood is offline   Reply With Quote
Old 05-25-2013, 02:03 PM   #5
You have as much torque as you are going to get in that size package. You can double up with another 7980 or you can look at the bigger options. Compare servos here: All RC Servos - Servo Database That link should have them organized by torque but if not just click on torque at the top.
Old 05-25-2013, 02:09 PM   #6
Maybe?
A 7980 will break a lot of stuff....thus my question.
I wanted to know why the OP thought it was underpowered. I was not asking your thoughts.
Frankly, if a single 7980 does not do it...there are many other issues....do you agree??
Sheesh, I have enough issues with a 7950 or a external powered BLS197(?) in a 2.2 rig.
BTW, a 7980 is already larger than most 2.2 rigs can handle "standard", if a 7980 is not enough (already making mount adjustments), why go even bigger???!!!
Old 05-25-2013, 03:02 PM   #7
When he said "big scale crawler" I figured we weren't talking about a 2.2.
Old 05-25-2013, 03:33 PM   #8
Hi guys, thanks for the replies
The CC BEC is set to 7.5volts, so hopefully it's getting enough juice.
Thanks for the link for all the different servos, I'll have a look through it and see if there's anything that might do the job.
I didn't want to go any bigger servo wise, but it's looking like I might not have any choice.
As far as the truck goes, it's got an 18" wheelbase, 40 series wheels and tires, 1/8 scale brushless system, Summit trans, Twinforce axles, solid body with exo cage....And weighs ALOT, lot 32.5lbs. All custom chassis etc, taken along time to build. It's nicknamed Heavy Duty.
Old 05-25-2013, 04:04 PM   #9
Buy a Hitec HS-1000SGT
Torque @ 11,1 V : 84,0 kg
Torque @ 14,8 V : 110,0 kg
fritzthefly is offline   Reply With Quote
Old 05-25-2013, 04:05 PM   #10
Not trying to get off topic here, but id like to see pics of this thing!
And hope you find a servo to fit your needs. I'm not schooled on anything bigger than 7980..
Good luck !!
1r3land is offline   Reply With Quote
Old 05-25-2013, 04:08 PM   #11
32+lbs?! wow man, a couple 7980's per front wheel perhaps?
Meatwad is offline   Reply With Quote
Old 05-25-2013, 07:30 PM   #12
Really 32lbs ????
Pictures of that beast please........
Postclanker is offline   Reply With Quote
Old 05-25-2013, 07:30 PM   #13
Based on a 32lb rig, neither one of us was close....
OP, in my eyes, you're on your own on this one....sorry......
Old 05-25-2013, 07:35 PM   #14
Natedog's Avatar
Yes,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 05-25-2013, 07:42 PM   #15
Norton's Avatar
Pictures please.....
Norton is offline   Reply With Quote
Old 05-25-2013, 07:42 PM   #16
you go big or go home.
Tonegawa Seiko SSPS-105 Servo Specifications and Reviews
5,277.0 oz-in
activethunderrc is offline   Reply With Quote
Old 05-25-2013, 08:46 PM   #17
How do you have your bec wired?
Do you directly power the servo?
So plug bec into servo + and - and signal to rx?
Or do you use the bec to power the rx then left over power goes to servo?
I run a 7980 on either end of my 1/8 crawler and use a bec for each servo. I run the bec straight to the servo. It's a lot better for getting most power. It's worth checking how you have it wired.
filotr14lsdude is offline   Reply With Quote
Old 05-26-2013, 12:42 AM   #18
Got Worms?
You might as well throw a hydraulic pump on there and go fullhydro steering at that weight
You can try a gear box
SPG400A-45 Standard Rotation
losikid is offline   Reply With Quote
Old 05-26-2013, 01:18 AM   #19
Suck it up!
Duuuuuuuude's Avatar
Or go pull a rack and pinion setup from an old Pinto...
Duuuuuuuude is offline   Reply With Quote
Old 05-26-2013, 05:22 AM   #20
Ohhhhh interesting! I'll look into those further, list price is though $429 But I'll see how it goes. Thanks man
Originally Posted by activethunderrc View Post
Big. You mean GIGANTIC! Next time I wanna pull down a tower block I'll be all over that. Its mega!
The ESC powers the RX, the BEC has a its own feed and powers the 7980 on its own. Have I got this right?
I'll go get a gas axe and a welder Thanks for the link on the gearbox, just about to click and have a look.
I'll sort out some pics for those who want them
What do you do when a Hitec 7980 and Castle BEC Pro aren't enough? - Similar Threads
Castle BEC w/ HH BR-XL and Hitec Servo AsILayDying Newbie General 2 08-29-2011 03:54 PM
Castle BEC Pro JeremyH Electronics 7 08-23-2009 01:10 AM
