Thread: Overheating problem
Old 08-19-2013, 12:49 AM   #1
idk
Default Overheating problem
My r2d is so hot I can't touch it. Haven't had a thermal shutdowns but I can't touch the motor tranny or skid.
My setup
Sv2. CC bec@6v
19t turn integy
Airtronics servo
R2d with 13tooth pinion
I'm thinking the motor is just to fast for the tranny. But idk going to a Hh 27turn soon but need this to last atleast 2 months had a 10tooth on and it was way way slower. No wheelspeed. I'm may try a 11tooth. Anyone got a suggestion.
I'm real happy with my wheelspeed my torque could be better. I'm just stuck on what to try
Sent from my SCH-I510 using Tapatalk 2
idk is offline   Reply With Quote
Old 08-19-2013, 05:07 AM   #2
Default Re: Overheating problem
If there is no binding in the drivetrain & the pinion/spur mesh is correct, then you're overgeared. Go to a smaller pinion.
Charlie-III is offline   Reply With Quote
Old 08-19-2013, 06:10 AM   #3
Or take off the body and go faster!!!!! Lol jk yes u are definitely over geared for your driving style, terrain, and power source thus causing excessive heat.
Btw 19t is pretty hot for even a trail rig. I had a Holmes 16t and that was just ridiculous...went back to a Holmes 35t...the torque and punch make up for top speed. 35t on 3s or 4s is ideal with proper gearing for both.
alexchen86 is offline   Reply With Quote
Old 08-19-2013, 06:42 AM   #4
idk
Yes I agree 19turn is way fast a 35turn on 3s is perfect.....with a axial granny with the lower geared r2d it was just to slow. I'm not racer just want my wheelspeed.I'm gonna try a 11tooth if that's no good a axial tranny will be next. Thanks for insight
Old 08-19-2013, 09:52 AM   #5
idk
Went to a 35t esc still hot still on 13tooth pinion I will try a 11 later. I never had a problem with rc4wd trannys. Before idk
Overheating problem - Similar Threads
Hitech HS-7954SH servo overheating problem??? newtocrawling Electronics 7 03-29-2011 03:52 AM
Fx-r overheating Jay2380 Newbie General 9 03-29-2010 09:47 AM
Overheating problem HELP!!!!!!!!!!!!! crazydevil97 Newbie General 5 02-01-2008 10:04 AM
Overheating CarsonWyckoff HPI Wheely King 4 09-13-2007 09:32 PM
sr problem? maybe overheating? rockbound Electronics 12 06-15-2005 06:34 AM
