09-01-2013, 10:08 PM | #1 |
Rock Stacker Join Date: Apr 2013 Location: Van Buren
| FS GT3C Problem / Need help
I've owned my GT3C for about 5 months now and I love it. I have had ZERO problems with this radio until today. The select button/wheel stopped working. I had just installed a new micro servo for the dig switch on my highly modified RS10 XT and wanted to make a small adjustment to the end points. At first all was fine....press the wheel scroll to EPA, press, scroll to Ch.3 press to select, but this time nothing happened when I pressed. I try again, same result. Now no matter how hard or soft I press it will not work. The wheel will still scroll but I can't select anything. I turned it off to exit the menu so I could try again but now I can't even access the menu to make any adjustments. Anybody else have this problem? If so what did you do to fix it? Thanks in advance guys. ***This radio has never been hacked, hell the only time its been opened was to install the battery. Last edited by KC5H; 09-02-2013 at 06:35 AM. Reason: Note* |
09-02-2013, 07:59 AM | #2 |
| Re: FS GT3C Problem / Need help
make sure you have fully charged batteries in it. 9.5v and under & it starts to do crazy things
09-02-2013, 08:22 AM | #3 | |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| Re: FS GT3C Problem / Need help Quote:
I can't say I have had this issue but perhaps something has gotten in there and is stopping the push button switch. I would also take it apart and look for a bad solder on the switch/selector. It may be the solder joint just woke up one morning and said F it. If you go here there is a hack tutorial that will explain how to remove the case to look. http://www.overkillrc.com/GT3C/Insta...anual%20v0.pdf | |
09-03-2013, 07:45 AM | #4 |
jaloos,,,,,I finely got inside of the radio and guess what I found, Yep a bad solder joint. 10X magnifying glass and 30 watts got that dude fixed right up. |
FS GT3C Problem / Need help - Similar Threads | ||||
problem calibrating a tekin rs to a gt3c | m1009cucv | Electronics | 7 | 07-05-2013 02:57 AM |
GT3C: Need your opinions | losikid | Electronics | 12 | 03-21-2013 05:47 PM |
GT3C Problem | WooPigSooie | Electronics | 11 | 11-05-2012 06:26 AM |
