09-11-2013, 08:28 PM | #1 |
| Post your preferred Stacked ESC wiring.
I am making some ESC stacking jigs to make it easy to stack neatly at home. How would you prefer the jigs to hook up to your system? Regular Deans mounted direct to the ESCs? Wires such as 16g coming off the block? Other method such as direct mount micro deans? This system will harness the wires, make assembly easy, and possibly offer a more compact solution for power caps. Whats your preference on power input? Thanks! |
09-11-2013, 08:40 PM | #2 |
| Re: Post your preferred Stacked ESC wiring.
I don't stack (I solder the esc directly to the motor tabs and servo tape the other end of the esc to the can) but either way I think the mini t plugs are the best for comp rigs. Smaller and lighter than deans but more robust than micro deans. |
09-12-2013, 04:41 AM | #3 |
Pebble Pounder Join Date: Dec 2008 Location: Finland
All wires should come out from one end of esc pack. Connectors are better to be in wires, as esc's are often in tight spot hidden in car and PCB's don't get so much force when you can hold wire when unplugging batteries. Cap's, wires etc. should be placed so that waterperoofing with shrink wrap is possible. EC2 connectors are also good choice |
09-12-2013, 08:21 AM | #4 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
front motor wires, battery wires and rx plugs out the front. rear motor wires out the back. Micro Deans plugs for batteries or just leave them open ended for the end user to cut to length and use whatever connector is prefered. 18 gauge wire throughout. Any options to use a cap in the same configuration as the CCSWM's? Thats the only thing I liked about those ESC's LOL |
09-12-2013, 08:27 AM | #5 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
Like above have batt/front motor and rx out the front and the rear motor out the rear. Use 18ga. wire for all and leave all connector's up to end user. If your able to make a smaller package this way that would be great and save use users time and effort.
09-13-2013, 12:51 PM | #6 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Front: batt in, motor out, servo out Rear: motor out All micro deans. Thanks a bundle John. Great stuff. Looking forward to running them. J |
09-14-2013, 01:30 AM | #7 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
I would like.... 1. Front motor wires, Battery wires, Rx connection wires come out from the front; 2. Rear motor wires come out from rear; 3. 18 gauge wire for motor and battery wires, no connector; 4. Similar cap as MSW (in-line), best to use 1 bigger one for both ESC; 5. Rx wire only 2-3 inches long; Motor and battery wire long enough for most application 6. 2 wire from the battery connection (either with JST connector or bare wire) for BEC connection. 7. Not sure if this can be easily done, on the ESC, there is a little jumper to disable the built-in ESC, so the whole plug (with 3 wires) can be plugged into the RX without removing the red wire on one of them, That will make the wiring cleaner. 8. Some sort of water-repellent coating (not liquid e-tape, some transparent stuff) apply on the esc. Hope that is not too much to ask.... Last edited by Colgout; 09-14-2013 at 02:04 AM. |
09-14-2013, 04:39 PM | #8 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
How about a single board with 2 adjustable esc's on it, No stacking, no spaghetti wiring mess, no shrinking together, no shorting possibilities I'd buy a few...............just saying |
09-14-2013, 09:26 PM | #9 |
The "single" board would be twice as big of footprint, we are already using two boards on each ESC to reduce the largest plane. Stacking is the best way to keep it compact, and having two discrete ESCs makes it less expensive to repair/ replace if one breaks. What we are gaining in this discussion is the popular construction needs. The "at home" jig will be the production jigs, we will offer complete dual ESC units soon. Just like I don't like painting and prefer it done for me, I'm sure most people don't like soldering nor do they have a nice heatgun. So how would you like yours set up if we did the work for you? |
09-14-2013, 09:43 PM | #10 | |
| Re: Post your preferred Stacked ESC wiring. Quote:
09-25-2013, 04:43 PM | #11 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
Stacked but as simple as can be yet efficient for total noobs like me. Like stoopid proof. Cheers eh, Todd Last edited by Tossedman; 09-25-2013 at 04:51 PM. |
09-25-2013, 05:50 PM | #12 | |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
09-26-2013, 07:46 AM | #13 |
Coming up with a smaller cap would be the largest improvement made to the BR Minis. I've done a few sets recently...1 pair for my Berg, 1 pair for my XR, 1 pair for my Super, 1 for my 2.2S. What I've been doing is cutting a section off of a 3.5mm female bullet connector and using that soldered between the battery connections on the board. It makes the connection rigid and eliminates the need for a foam block or anything between them to hold more heat in. The rear motor wires are attached to the lower board and run out the back. The battery leads and BEC leads are attached to the top of the board on top and depending on the wire gauge being used I can attach the front motor wires to the underside of the top board or to the top of it and run them out the front as well. This is the last set I just did for my Berg: This was the first set I did, which were for my XR Last edited by ittybitty; 09-26-2013 at 07:48 AM. |
09-26-2013, 10:25 AM | #14 |
I was thinking about milling out a Delrin spacer, to put between my sidewinder micros, and then putting a small fan like this in a tight package. Not huge, only 5.0v, but thinking it would keep things from getting too hot. All you would have to do is shrink wrap the assembly, trim out for the fan and the exit on the other side.. |
Post your preferred Stacked ESC wiring. - Similar Threads | ||||
Tf2 stacked up to scx10? | Rivas Concepts | Scale Videos! | 18 | 06-19-2012 11:21 PM |
esc wiring help | boohoo | Losi Micro-Rock Crawler | 7 | 03-26-2011 10:45 PM |
ESC Wiring | jcraw | Redcat Crawlers | 4 | 02-25-2010 05:51 PM |
stacked trannies | Bknight | General Crawlers | 12 | 06-28-2006 10:18 PM |
