09-17-2013, 06:46 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: NZ
| Dig install with dual motor esc?
Hey guys, iv got an rc4wd dig unit on the way.. I was just looking at the wiring diagram and am a bit confused as to how I would set it up.. as iv got a dual motor esc? It looks to me like the diagram has been drawn for a single motor ESC? Can anyone point me in the right direction as to how to set this up? Would I just double the wires up that run to the DIG? (i.e solder both red ESC wires together, solder both black ESC wires together - then connected those to the DIG? Any help appreciated. Thanks guys |
09-17-2013, 06:49 PM | #2 |
| Re: Dig install with dual motor esc?
What radio do you have? What escs?
09-17-2013, 06:52 PM | #3 |
I will run a DX6i...i just have the rc4wd dual motor esc. So its one esc but has two sets of motor wires. Thanks |
09-17-2013, 06:54 PM | #4 |
| Re: Dig install with dual motor esc? |
09-17-2013, 06:57 PM | #5 | |
| Re: Dig install with dual motor esc? Quote:
Iv just got the DIG unit, so am not going to go buy two escs and not run the DIG that i just bought . Thanks | |
09-17-2013, 07:10 PM | #6 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
Don't know much about the ESC you are referring to, but does it have 2 set of Rx wire? If yes, you can run it off the your stick tx and mix them using the radio and no need the dig unit. Otherwise, I guess just use the esc with one set of motor output and use your new dig unit to control the 2 motors.
09-17-2013, 07:15 PM | #7 | |
I think iv found the answer. Looks like i just need to use one set of wires and un solder the other two. could i run a punk dig on a outcry esc? | |
09-17-2013, 08:47 PM | #8 | |
Dig install with dual motor esc? - Similar Threads | ||||
Dual esc. or Punk Dig? | J-VET | Axial XR10 | 15 | 01-03-2012 10:59 AM |
Dual ESC vs. Single ESC and Dig | zjguy721 | Electronics | 12 | 02-21-2011 08:08 PM |
