10-10-2013, 07:29 AM | #1 |
Rock Crawler Join Date: Oct 2011 Location: Canada
| CC BEC Setup Diagram for HV Servo at 7.4v
Quick question, no flaming, I've "used the search button" and RTFM. Lots of opinions, and sketchy diagrams. Just want to show my diagram and get a quick Yes or No before I blow something up, and if it is correct, it may help other people. Thanks for the help in advance! version 2 added with the advice of the experienced members below Last edited by Arctic Fire; 10-10-2013 at 01:06 PM. |
10-10-2013, 07:35 AM | #2 |
| Re: CC BEC Setup Diagram for HV Servo at 7.4v
I run it like that but I don't connect the bec yellow wire to anything. You may want your black servo wire connected to the rx if you get glitching.
10-10-2013, 07:55 AM | #3 |
You can also make the servo have two plugs. one for the Rx wire only and one for the pos/neg to BEC. I have a rx/tx plug crimper tool so it's a clean setup for me. Best $21 ever spent. Servo Connector Crimping Pilers Plug the BEC into the +/- plug on the servo and plug the servo rx wire into the rx. ... Last edited by Szczerba; 10-10-2013 at 07:58 AM. |
10-10-2013, 08:12 AM | #4 |
I've heard about leaving the black wire in, so I will try that too. That tool is pretty slick, I like the BEC/ESC all bundled up. I think I like having the Y adapter in there, If I have to change a servo in the field it allows for a universal install, and I can borrow a buddy's spare servo as a last resort and keep going. |
10-10-2013, 08:27 AM | #5 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
Remove the signal wire from the Y harness that the BEC plugs into, that way you just pop it out of the harness for programming. Use the black wire from the servo to receiver as mentioned earlier to avoid glitching. I would also add a small connector in the power feed to the BEC. In my application I removed the power switches to my dual sidewinder micros and hard wired the powers all together and now I cannot program the BEC due to power feedback going to the ESC's, so a way to isolate the bec would bea good idea. |
10-10-2013, 08:33 AM | #6 | |
| Re: CC BEC Setup Diagram for HV Servo at 7.4v Quote:
10-10-2013, 08:35 AM | #7 |
| Re: CC BEC Setup Diagram for HV Servo at 7.4v |
10-10-2013, 08:38 AM | #8 |
10-10-2013, 08:45 AM | #9 |
| Re: CC BEC Setup Diagram for HV Servo at 7.4v Ah that may be why never had the battery plugged in. I am also using the field programming card as the interface to the PC if that makes a difference. I just tested it with the neg wire cut from the power connection and it is fine now. The way it was before there was power going to the micros from the BEC, must be some sort of power feedback or something that having the battery hooked up would have eliminated. Nothing a little micro deans, jst connector a a tiny micro switch can't fix in the rewire I am going to have to do since I cut the wire LOL. Side note is an 18 guage from battery to both esc and bec ok? |
10-10-2013, 08:45 AM | #10 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: CC BEC Setup Diagram for HV Servo at 7.4v Yup.... Bec plugged in to castle link..... Castle link on...... Then plug in you rigs battery and castle link will then sync. Also I build my own splitter harness..... Just stop the signal wire from bec to servo in the splitter like said above. Last edited by JokersWild; 10-10-2013 at 08:48 AM. |
10-10-2013, 08:48 AM | #11 | |
Oh well wasn't too thrilled with the wire job as it was, used 14 gauge wire to the esc and bec but it is too bulky and stiff for my liking. | |
10-10-2013, 09:10 AM | #12 |
Side note is an 18 guage from battery to both escs and bec ok? Guess its not a big deal as the batts have 18 coming from them in the first place. |
10-10-2013, 09:12 AM | #13 |
10-10-2013, 09:15 AM | #14 |
10-10-2013, 09:19 AM | #15 |
10-10-2013, 09:19 AM | #16 |
BTW sorry for the hijack of your thread Arctic Fire.
10-10-2013, 09:46 AM | #17 | |
I use the CC USB cable, hook it all up and plug in a charged rig pack and program away. | |
10-10-2013, 12:33 PM | #18 | |
Thanks guys appreciate it. | |
10-10-2013, 01:03 PM | #19 |
Awesome hijack, I just learned a bunch. Here's the updated diagram with inline removable plug and connectors, completely removable, adjustable and transferable |
10-20-2013, 05:33 PM | #20 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
Quick question guys my servos are rated at 7.4 volts I've got 1 for steering and 1 for rear steer. Do I need a bec for each servo or can I run 2 off of 1 10amp cc bec? Also since I have a shift servo will I still be safe running the rx and shift servo off my mmp esc bec? Sent from my iPhone in the shop |
CC BEC Setup Diagram for HV Servo at 7.4v - Similar Threads | ||||
Can't find it... Diagram for BEC on Servo only | Orph3o | Axial XR10 | 20 | 10-28-2012 07:53 AM |
BEC and other wiring (see diagram) | pritch | Electronics | 4 | 09-11-2011 05:20 PM |
Tekin FX-R and CC BEC diagram | cliffhanger007 | Electronics | 64 | 07-03-2011 01:33 AM |
BEC Wiring Diagram... | justinart24 | Electronics | 0 | 12-15-2010 11:16 PM |
mamba max, cc bec, servo, battery setup | quarterpounder | Electronics | 8 | 02-21-2009 11:44 PM |
