11-12-2013, 11:02 AM | #1 |
| Flysky receivers
Has anyone used them underwater? Spectrum cuts out under water, Futaba does not, does Flysky? Anyone have experience? |
11-12-2013, 06:22 PM | #2 |
| Re: Flysky receivers
Anyone using Flysky in scalers in H2o?
11-13-2013, 07:04 PM | #3 |
I've had mine submerged in a radio box and it didn't lose connection. The radio box is pretty high and was probably less than an inch under water. Though, pretty much all 2.4ghz will lose connection if the antenna goes more than an inch below the surface of the water, it's just a matter of signal not going through water. Your best bet is to run the antenna as high as you can. |
11-13-2013, 07:08 PM | #4 |
| Re: Flysky receivers |
Flysky receivers - Similar Threads | ||||
Flysky fs-t6? | Tgreer | Electronics | 12 | 09-16-2013 04:13 AM |
flysky problems.....need some help.. | pugs2300 | Electronics | 3 | 02-13-2013 08:20 AM |
FlySky GT-2 TX | WAM | Electronics | 6 | 09-19-2011 06:55 PM |
